F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Turn signal problem
Old Nov 23, 2018 | 10:58 PM
GDGR's Avatar
GDGR
Turn signal problem
Car says the right-rear turn signal is malfunctioning, and the right side is flashing quickly. Yet all three bulbs (headlight assembly, side scuttle, and taillight) are functioning normally - other than the fast-flash.
What gives? Everything is stock and original. Anyone else seen this?
Old Nov 26, 2018 | 06:11 PM
GDGR's Avatar
GDGR
I figured this out. It was the inner bulb on the bumper, you know, the one that never comes on.
Old Nov 26, 2018 | 09:21 PM
Eric_Rowland's Avatar
Eric_Rowland
That's for rear fogs, yes?
If so, do you have them, or is the bulb just there?
Old Nov 26, 2018 | 10:40 PM
GDGR's Avatar
GDGR
No, the rear fogs are on the side of the big cluster on the barn doors. I have coded them to work with the brake lights.
The inner bulbs on the bumper were brake lights when I bought the car, but a later recall turned them off. I think they can also be set up to be used for extra brake lights under emergency braking, but that feature doesn't get enabled in US cars.
What they *DO* do is act as a turn signal when your barn doors are open -- my barn doors weren't open, but that bulb's failure was enough to trigger the brake light failure warning.
gob15
Oct 14, 2018 02:30 AM
Sigboi
Oct 2, 2016 11:21 AM
tgr4tgr
May 14, 2014 06:49 AM
gaz.pike
Sep 7, 2013 03:17 AM
