Electrical Tail light connectors - Where to get them?
Old Oct 7, 2005 | 09:45 AM
Brent@minidomore.com's Avatar
I have seen the Official PDF instructions for the 2005 tail light retrofit kit on Motoringfile.com See here - http://www.motoringfile.com/files/2005_taillights.pdf
But, does anyone know where one could get just the connectors? I have another idea I want to work on and would love to know how to get the connectors if possible.
Old Oct 10, 2005 | 10:41 AM
1FSTMINI's Avatar
1FSTMINI
Are you putting newer lights on an older car....Or the white lights on an 05'?
Old Oct 10, 2005 | 02:17 PM
mini-rolls's Avatar
mini-rolls
Are you looking for the coonectors at the taillights or more?
Old Oct 10, 2005 | 08:02 PM
I am trying to make an adapter to patch in trailer light and a plug. Using the connectors from the retrofit kit (the kit to fit 05 lights on earlier models) and my own wiring to a Drawtite powered modulite unit, I could make make this adapter, using the signals from the lights for the modulite. This would allow for a clean adapter with no splicing or cutting and could easily be removed if need be.
Old Oct 10, 2005 | 08:50 PM
not-so-rednwhitecooper
yeah, ive heard of lots of problems when people tap into the factory stuff for a trailer harness.
besides, the retrofit kit for an 05 changes the wiring configuration from one end to the other.
it wont work correctly on an 05, it will make 05 tail lights act like 04 tail lights.
Old Oct 11, 2005 | 09:19 AM
Jdewey's Avatar
Jdewey
tail lightwire access
Here is how I did mine:
http://user.mc.net/~jdewey/MINI/Trai...MINI_wires.jpg
It is described at the end of this file:
http://user.mc.net/~jdewey/MINI/Trai...r_Hitches.html
To make the connection I did not cut, strip, or tap the MINI wires. I unplugged the MINI connector
from the taillights. I then carefully unsnapped the plug cover, and used a knife to release the barb
(twice on each terminal) and pull the wire out of the plug. Then I stripped the module wire and
wrapped it around the terminal several times, and reinserted the terminal into the plug, replaced
cover, and reconnected the MINI lights. If you ever need to remove it there will be no "evidence".
See the photo named "Mini_wires".
COLOR CODE for a 2004 is here.
http://user.mc.net/~jdewey/MINI/Trai...olor_codes.htm
It has been in place for about 18 months now and is still working fine.
John
Mb460
Aug 20, 2016 10:39 PM
smarsha11
Aug 24, 2015 06:03 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
