Electrical Factory alarm v. Hornet 727t
Old Aug 11, 2005 | 11:22 PM
Nuff's Avatar
Nuff
DEI makes the Hornet 727 (they make Clifford and Viper alarms). Great thing about it is that you don't need an extra key fob - it uses the Mini built-in keyless entry - it seems silly to have to have a separate remote to activate the alarm.
Plus, you can find it for around $70.
http://www.directed.com/security/hornet/horn_ke.asp
Anyone try this?
Old Aug 12, 2005 | 12:11 AM
kbseto's Avatar
kbseto
haven't tried the hornet specifically, but i have tried the viper alarms...the main complaint i have with my viper was the frequency of false alarms, ie. it will sound off with excessive vibrations, as that is how it guards your car. the shock sensors will detect glass breakage, bumps against your exterior, or even vibrations, ie. bass-blasting car stereos or the garbage truck or even harleys. yes, you can get it adjusted, but it is a pain to keep bringing it back to get it fine tuned, as it will change over time.
i like the oem alarm because it does not use the shock sensors, but instead uses motion and tilt sensors. virtually fool-proof i believe, as there are no false alarms with accidental bumps at the parking lot or with loud noises.
the trade-off is that you do get only minimal protection, if any, on the exterior, as the motion sensor only detects movement inside the car. of course, if you have the windows even partway down and someone walks by, it can sound off, possibly another negative if you wanna keep your car a bit ventilated during the summers.
but for $70, that sure sounds like a steal, as DEI is a pretty good company. + you get to use the factory key.
Filmy
15
Jun 6, 2023 06:27 AM
Sep 10, 2015 11:55 AM
Gen1Parts
Sep 7, 2015 03:50 PM
Sep 4, 2015 02:34 PM
Sep 4, 2015 11:43 AM
