Electrical CPU R53S in a cooper
Old Nov 4, 2020 | 11:40 AM
Thierry-77's Avatar
Thierry-77
Hi guys
a friend would like to build a R53 turbo with a basic mini cooper .
he would like to put in it a R53 170hp CPU.
Will it work ? With right VIN and EWS match of course
Old Nov 22, 2020 | 12:58 PM
cut7's Avatar
cut7
I think you'd be better off using an aftermarket drop-in ECU like the one from Link, because you're going to have to put bigger injectors in & completely re-tune it. The stock map won't work, I guarantee it!
Old Nov 23, 2020 | 10:20 PM
Thierry-77's Avatar
Thierry-77
We steel have injector and bytetronik for the map , and I am the " map tuner "
1320mini build mini turbo with OEM ecu so .....
a link ECU is almost 1000$ , to mutch ...
Old Nov 24, 2020 | 01:50 PM
cooper48's Avatar
cooper48
The ECU swap will work as long as it's programmed to the VIN and keys. I have a stock 2004 ECU with a loaded Dinan Stage 1 tune I'll let go for $100 + shipping if you're interested. This tune bumps the stock 163hp to 175hp.
Old Nov 25, 2020 | 01:24 AM
Thierry-77's Avatar
Thierry-77
No thanks we will reach 300-350hp with the turbo
Old Nov 25, 2020 | 03:48 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
adrian can send you a ecu that wont have to match your current keys/ews, also known as immobilizer removed.
I use one in my car, can move the ecu to either of my r53s and it does not care. He also can tune for turbo including fixing the boost limit
electricalbox
Feb 20, 2016 01:00 PM
TheCanyonCarver
Jan 7, 2015 09:40 AM
MINIkinetics
May 7, 2011 08:40 PM
aletstrejo
Mexico
Jul 26, 2009 12:53 AM
