Electrical 04 fog wiring issue?
Old Jun 25, 2014 | 10:05 AM
PFCflanders's Avatar
PFCflanders
Hey guys, so I just installed a set of HID bulbs in my fogs about a month ago. Now the left side is out, but the right is working fine. When I had my Halogen bulbs in there the left side had gone out as well. Im pretty sure its not a coincidence because it literally was working fine, then i turned the car off and came back an hour later and it didn't work.....
Any info on this would be much appreciated! I guess if it comes down to it i'll just order another HID bulb and see if its just the bulb that has issues .....
Old Jun 25, 2014 | 11:59 AM
ZippyNH's Avatar
ZippyNH
You since you are not sure the bulb is bad....you try swapping both bulbs side to side to see if issue follows the bulb....
Xenon bulbs are almost always replaced in pairs.... Their color+ brightness change with use....and bulbs "wear" by turning on/off, not by hours of use by the nature how xenon bulbs work....
Unfortunately aftermarket kits have terrible ballasts/ignitors and bulbs....
Old Jun 25, 2014 | 12:41 PM
astroBlackMetallic_Mini's Avatar
if swapping bulbs blows your other bulb, you can try adding another ground wire. i had a similar issue in my old celica (and sort of in this mini). i put in those led projector puddle lights, and the passenger door one keeps burninng out. its wired right, and it is hard to trust chinese leds, but im thinking of adding another ground anyway to try an alleviate the issue. worked on the celica's rear bulbs anyway.
Old Jun 25, 2014 | 04:05 PM
PFCflanders
Thanks for the imput guys. I "borrowed" a h11 bulb out of my friends car and it worked on that side, so i guess the bulb must be bad. I got the kit from ddmtuning.com and i've heard positive reviews from them so far. Guess I got a bum set.....
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
Aug 19, 2015 12:51 PM
JHolland
Aug 13, 2015 10:47 PM
