Electrical R56 - A/C Compressor Relay
Old Oct 13, 2019 | 07:15 AM
  #51
Lex2008's Avatar
Lex2008
You mean the electric harness?
Did you do a motor swap? Is that why you cant find it?
Old Oct 14, 2019 | 07:16 AM
  #52
jbpkruppa's Avatar
jbpkruppa
In my case, A/C wasn't working. After sometime searching, I realized that somebody previously has changed the first and the second fan rellay positions. That made car computer to keep air conditioning out of service...
Old Oct 14, 2019 | 07:25 AM
  #53
Lex2008's Avatar
Lex2008
Glad you found the cause of the problem! Awesome!
Old Feb 1, 2020 | 03:16 AM
  #54
Mustafa Kemal Caglar's Avatar
Yes motor swap and o think cable is cut
I found a White cable but o cant get any woltage when ac on or off
Old Feb 1, 2020 | 04:10 AM
  #55
I think its relay shortcircut and stop working
Old Jan 9, 2022 | 08:24 PM
  #56
idibidi's Avatar
idibidi
Changed relay positions?
Do you mean someone swapped the relays with each other or another relay? I was checking some other issues and may have swapped those two relays. Will that keep the AC from coming on? I am not getting power to my AC clutch but it works if powered directly.
Old Oct 4, 2023 | 10:05 AM
  #57
trlman's Avatar
trlman
Working on 2010 R57 JCW, after taking dash apart to install new radio head, no A/C. Panel lights up, no output to compressor. Checked all fuses, have not heard relay click.
Checked white lead out of fuse box, no current. Applied 12V compressor engages.
Does anybody know which wire it is that trips the relay out of back of A/C control? This car has the automatic A/C
Trying to determine whether it is bad control or relay, or maybe i dislodged a wire.
Thanks for any possible help
Old Oct 4, 2023 | 10:27 AM
  #58
Lex2008's Avatar
Lex2008
Are you asking for a wiring diagram?
Old Oct 4, 2023 | 11:07 AM
  #59
trlman's Avatar
trlman
I guess so, I have Bentley but can't make heads or tails of those pages.
Old Oct 4, 2023 | 11:16 AM
  #60
Lex2008's Avatar
Lex2008
only thing I can provide is a wiring diagram but ya need to send the VIN.
Old Oct 4, 2023 | 12:30 PM
  #61
trlman's Avatar
trlman
ElectricalR56-A/C Compressor Relay
Vin# WMWMS9C51ATK19831
Old Oct 4, 2023 | 12:39 PM
  #62
Lex2008's Avatar
Lex2008
Old Jun 26, 2024 | 06:13 PM
  #63
javieer.x's Avatar
javieer.x
Originally Posted by 3d914
dave, already tested that. The low side had excessive pressure - which is what lead me to the compressor. Since clutch is not engaging I can't get an accurate reading on coolant level. It was working great - and just quit. So hopefully its just wiring issue.
Anyone have a simple schematic of the R56 A/C system?
Edit: Thought I found something on BMW-Planet - but guess what - the pages I was looking for had bad links -bummer.
Hi ima having issues with my mini r56 AC since all of a sudden the ac isn't blowing cold air. its not the first time it happens I do believe it was a wire issue but somehow they got loose and I have no clue which ones to connect.
Old Jun 26, 2024 | 06:22 PM
  #64
javieer.x's Avatar
javieer.x
I also need help with knowing where the electrical wiring harness of the mini goes!! For the ac compressor it might’ve disconnected because the ac isn’t blowing cold air it’s not the first time it’s happened I did take it to the shop last year and they had told me it was an electrical issue which I assume was the wire of compressor and some other wires that were damaged. I do see a red and green wire from the compressor and the other two I see hanging are brown and white. I want to connect the four cables, but I'm not sure which color corresponds to which connection.
Old Jun 26, 2024 | 06:23 PM
  #65
Lex2008's Avatar
Lex2008
The yellow plug plugging into the compressor is a weak point. Check it.
rtk90
Aug 29, 2019 09:08 AM
embiggenedmini
Oct 15, 2015 12:36 PM
TrueEddie
Sep 2, 2015 11:43 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
damncajun
Aug 17, 2015 08:25 PM
