Electrical HeadLight Washers Stopped Working
Old Apr 18, 2014 | 09:52 AM
cmacattack's Avatar
cmacattack
Anyone have this problem? They just stopped working, the fuse is fine. Anyone have this issue and been able to fix it yourself without going to the dealership?
Old Apr 18, 2014 | 10:11 AM
Check the fuses first , then check the washer pump in the tank. Make sure the tank does not have a leak.
The windshield washer fluid container goes around the lower fog light / postilion light housing on the driver side.
Windshield Washer Container ( Halogen headlights )
http://www.ecstuning.com/Search/SiteSearch/61677157124/
Windshield Washer Container w/ xenon headlight / washer jets
http://www.ecstuning.com/Search/SiteSearch/61667157121/
Regular pump for windshield and rear. #3
http://www.ecstuning.com/Search/SiteSearch/67128377987/
Headlight washer pump # 5
http://www.ecstuning.com/Search/SiteSearch/61672751744/
Check all the connection to the head light washer pump, also make sure no debris clogged the pump or port, can you hear the motor running down near the tank.
Then go to the jets themselves.
High Pressure Jet Headlight Washer - Right Passenger side
http://www.ecstuning.com/Search/SiteSearch/61677157120/
High Pressure Jet Headlight Washer - Left driver side
http://www.ecstuning.com/Search/SiteSearch/61677157119/
Old Apr 18, 2014 | 01:11 PM
cmacattack's Avatar
cmacattack
Wow, that's a lot of great info, thanks.
I'll have to check back after i've checked everything from your post, i've only skimmed it for now. I know the washer pump for the front and back windows works perfectly, it's only the headlight washers that stopped working. Do you know if they use a separate pump.
Old Apr 22, 2014 | 02:24 PM
heiker's Avatar
heiker
yes, there is a separate pump for headlight washers. there is a separate fuse for it (F32?) Moreover there is a dedicated relay in JBE for headlight pump.
Old Apr 23, 2014 | 07:44 AM
cmacattack - You are welcome, its a separate pump #5 in the diagram. Let us know what you find.
Old Apr 23, 2014 | 12:54 PM
rckrzy1's Avatar
rckrzy1
IMO the biggest not needed item on a car. In all my years of motoring never had to clean my head lights.
danielbrookes_9
Oct 3, 2015 12:51 PM
Alkaidovich
Aug 30, 2015 09:04 AM
R53Mom
Aug 17, 2015 01:38 PM
ludedude
Aug 10, 2015 07:16 PM
