Electrical any way have driving lights with low beam?
#26
I'm sorry, but what you're saying makes no sense to me at all.....
In one breath you're saying you need them right in front of the car (like a fog light only brighter?)
And in the next you say the high beams are aimed too high to do any good, yet you're driving on back country roads where you need to be looking way down the road, not 5 feet in front of the car.
So which is it? Are you trying to have a really bright set of fog lights, or are you trying to make sure you're not outdrving your headlights on back country roads?
What part of the country are you in?
I'm trying to understand your usage here, cause I'm afraid I agree with CR, I can think of no instance where low beams and driving lights make sense.
Low beams and fogs, sure. High beams and driving lights, yep......
High beams and fogs, not in the least - that would simply blind you. Likewise, low beams and driving lights is not a combination that makes any sense to me.....
A lot of people mistakenly think that they need to see very well right in front of the car, when what you should be doing is looking way down the road at the very edge of the headlight's illumination to plan your next move.
If what you're saying is the roads are low speed and very tight turns, then what would really help are headlights that turn with the front wheels. Who has those now, anyone?
#27
#28
driving lights currently aimed as low as they will go, highbeams as well, zero vision from right in front of the car to about 20ft. with low beams will aim the driving lights up to normal to see farther out. i live in southern washington and drive from my small town to a larger town for work. the roads i take are empty at night when i head to work. in the morning it light so i don't even use my lights.
i need to see in front of the car so i can avoid hitting a deer or other animal that decides to jump out in front of me. kinda like the one that did the other night. hence the question. but i would also like to see a ways out to be able to slow down and avoid things at a longer distance.
in all honesty though this is besides the point. i asked a simple question. i received a nasty response when it was in no way necessary. im fairly new to my car and to this board. its people like CR that make me not even want to be a member here.
#29
#33
For those still playing along at home, I think CR's correct in that shining the light immediately in front of you will not do what the OP thinks in terms of avoiding a deer or other animal, cause by the time you see it at less than 10 ft out, you're gonna hit it - you don't have time to react.
Far better to look up the road and scan the sides for eye reflections and other clues, and the more light you can get up the road, the better.
I hear this given as a reason for running fog lites all the time on clear nights, that it helps light up the sides of the road - it's a totally bogus reason tho...
You need to get your eyes up and look far down the road, not right in front of the car.
On really tight twisty corners, especially hilly ones, it doesn't help as much as on longer straighter roads, but it's still the better solution.
If the OP is on the road by himself and not encountering oncoming traffic due to his hours or the remoteness of his location, then having any combination of lights on won't be bothering other drivers, but anywhere I've ever driven there's going to be oncoming traffic at some point, you have to be quick on the trigger to make sure you don't blind someone and cause a wreck.
I hope that whoever sent him the PM explaining how to trip the relay and turn them on, also gave him a good and quick way to turn them off again......
#34
All of you!
I think you all are rude and don't need to lecture anyone. If you don't want to answer the question don't reply. Pretty simple. I like the question and if you know the answer then give it. Not your petty thoughts and ridiculous arguments to be rude. I can't believe what read above just asking a pretty fair question.
#35
#36
#37
Real piece of work. Very elitist attitude. Pompous actually. But you are in 6th gear and are allowed to pass judgement on others for asking a good question. I have a jeep and did the same thing because when driving at night you may not want all high beams but a mix on dark roads. Without cars, because believe it or not people on forums can bevreonsible adults for themselves and can choose right or wrong. No CR needed to decide for us.
#38
You think I was the only one telling him why it's a very bad idea?
And if he has the freedom to do something potentially dangerous, why do I not have the freedom to call him out on it?
Seriously... you don't see how his idea could present a dangerous situation? Maybe you can be the first person in the thread to tell us one good reason to have driving lights set up to come on with low beams.
#39
#40
You
You were rude, and honestly no one has to explain why they want to do something or their intentions. They may want to know because they want just want to do something. I am sure numerous people have thought about, or done it. Like I said I did it in my Jeep and would do it in my Mini. A) because it is my car B) I like low beam coverage on a dark road but like my driving lights pointed ahead to so the sides for deer C) no one has the right to pass judgement on my intentions if you do not know me. Me nor any other person on this forum has to explain our intentions or be judged by anyone. Again if you don't know the answer or do not want to explain keep the judging to yourself.
#41
#42
Would you want your wife, parent, children... driving toward a car with driving lights on?
I had a set and they are much brighter and project much further than high beams.
#43
No he was not! I never said off road anywhere. You made an assumption because I put Jeep. I use them on an everyday road where other cars drive. I again can make the decision to be rude or not. I choose not to because I agree it could be annoying for someone else driving up on me. I drive a lot of back roads at night and would enjoy using my driving lights with my low beams as well. Don't assume everyone has bad intentions or pass judgement because of the 5% who choose to be rude on the road. I can't find one story about someone wrecking because driving lights blinded them and caused a horrific accident as you insinuate.
Does anyone have a way to do the original request? I would like to know.
#44
#45
#47
And evenif it never happened before, that doesn't make this a good idea.
Wow.
#48
Ever consider you don't hear about problems this causes because there are so few selfish idiots driving around with their driving lights on with their low beams?
#50
