Electrical Installing Yellow HID Fogs, LED Running Lights on R60
Old Nov 8, 2011 | 11:27 AM
  #26
Theta's Avatar
Theta
I certainly can, so long as it doesn't offend Geoffrey - he was really the pioneer of R60 coding. I'll work on a writeup today.
Old Nov 8, 2011 | 07:30 PM
  #27
countryman-s's Avatar
countryman-s
AWESOME, thank you theta and geoffrey for cracking into coding the countryman. ya'll are definately pioneers. NAM members are the BEST!!!! for sure
Old Nov 8, 2011 | 10:32 PM
  #28
Theta's Avatar
Theta
Added a lengthy R60-specific coding guide a few moments ago in this section. Cheers!
Old Jan 10, 2012 | 07:36 PM
  #29
Smalls-'s Avatar
Smalls-
Can you post some more pics? I want to do this to my 09 Clubby
Old Jan 10, 2012 | 08:56 PM
  #30
Theta's Avatar
Theta
Sure, what would you like more pics of?
Old Jan 11, 2012 | 06:09 AM
  #31
Smalls-'s Avatar
Smalls-
I would like to see strait on pics of the front, from further back.
Old Jan 11, 2012 | 06:59 AM
  #32
Shatmepants's Avatar
Shatmepants
Theta, thank you for this write up. From the first time I turned on the factory "fog lights", I knew that they were going to need an upgrade in order to be useful to any significant degree.
I realize that you pieced yours together, but do you have any brand recommendations for those needing to buy a HID kit? I have heard about some poor performance from some the cheaper kits and would like to spend my money wisely.
Old Jan 11, 2012 | 11:22 AM
  #33
Theta's Avatar
Theta
You know, sadly, from the dozens of kits I've had over the years, I can say that most times a ballast is a ballast is a ballast. They all seem to be the same as far as quality, longevity, etc. In this case, I'd try to use a slim ballast, as it's going to make your job a lot easier.
As far as bulbs go, that's really subjective. Again, brands don't matter a whole heck-of-a-lot because most of the bulbs are still made in China (most likely at the same facility). As far as colors go, it takes quite a while to find the color you want from bulb sellers. It took me 6 sets to find a deep yellow set that I loved, which I ended up using in these.
Sorry if I've confused you even more, but that's really the truth out there. Even people selling Philips 'German' kits have been busted recently, as they're just Chinese clones. Everything's about the same now.
Old Jan 11, 2012 | 11:23 AM
  #34
Theta's Avatar
Theta
I will try to get a few shots of that tonight when it gets darker out.
Old Jan 12, 2012 | 06:15 PM
  #35
Shatmepants
Theta, thank you for the additional information. I'll start looking around for a kit with thin ballasts.
Old Jan 12, 2012 | 07:13 PM
  #36
Theta's Avatar
Theta
You're quite welcome! Here are the pics that were requested.
Sorry it's a bit late, but the weather's been weird here lately. I love my snow bunny, though.
Old Jan 13, 2012 | 06:16 PM
  #37
Smalls-'s Avatar
Smalls-
Looks good, thank you. I see you didn't need a code eliminator for the countryman. Do you think I'll need one for the R55?
Thanks again.
Old Jan 13, 2012 | 06:17 PM
  #38
Theta's Avatar
Theta
You absolutely will need a code eliminator for everything here!
I don't use them because I code all of my warnings out (on every single bulb check).
Old Jan 13, 2012 | 06:46 PM
  #39
Smalls-'s Avatar
Smalls-
Awesome thank you once again. Maybe I can find NCS Expert(er) at MOTD!
Old Jan 13, 2012 | 06:48 PM
  #40
Theta's Avatar
Theta
You'll be happier that way - much less of a mess than eliminators / resistors.
Old Jan 13, 2012 | 06:57 PM
  #41
Smalls-'s Avatar
Smalls-
I'm probably going to pick up the DDMTuning kit
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
Several on here recommended them.
Old Feb 8, 2012 | 04:14 PM
  #42
JPMM's Avatar
JPMM
So where do I find these bulbs?
special Philips OEM bulbs called 'Ultinons' that posses a closer-to-6000K look without any reduction in brightness. they give a purple-ish look that a BMW projector lens is supposed to put off. they are an approved Philips bulb. They are in the Xenarc/XenStart family,
Countryman-s, thanks for the compliment! The HID lights for the mains are not really blue, but they're not factory, either. They are special Philips OEM bulbs called 'Ultinons' that posses a closer-to-6000K look without any reduction in brightness. They are used on several high-end euro sports cars. More importantly, they give a purple-ish look that a BMW projector lens is supposed to put off. Most importantly, they are OE, and street-legal. They're also A-OK for warranty work on the factory ballasts, since they are an approved Philips bulb. They are in the Xenarc/XenStart family, and thus supported by Mini. It's good peace of mind, even though they're expensive.
A quick note, they're nowhere near that blue. Because of the ludicrously-bright 85w yellow bulbs in the Black Magics, I'm sure the colors are way off. I can digitally correct them to show you what the eye sees (it's more purple-ish white):
Old Feb 8, 2012 | 04:46 PM
  #43
Theta's Avatar
Theta
They're generally available from European dealerships - we have several here that stock these for MBs and such. Our Lotus dealer also sells them, as does the Lambo/Maserati dealership.
If you're going online, there are several places to pick some up, and can even be purchased on Amazon. They run anywhere from $100-130 per bulb.
Make sure they're the actual bulb (not the common knock-offs) - they are retail packaged and labeled under the Xenarc/Xenstart Philips branding.
Old Feb 9, 2012 | 03:16 AM
  #44
JPMM's Avatar
JPMM
which ones?
http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
Old Feb 9, 2012 | 11:20 AM
  #45
Theta's Avatar
Theta
None of those, sadly. I believe all of our cars use D1S bulbs with the igniter (ballast) on-board. D2S bulbs are made for other cards with outboard ballasts, and are much cheaper to boot.
If it helps, I can take a picture of the back of the bulbs (thought they'll just say Philips Xenstart, etc).
Old Feb 9, 2012 | 01:55 PM
  #46
JPMM's Avatar
JPMM
how about any of these?
http://www.highperformancebulbs.com/d1shidbulbs.html
Old Feb 9, 2012 | 01:58 PM
  #47
Theta's Avatar
Theta
There appear to be a set of Ultinon 6000k at the bottom there for $185, but I can't speak to their authenticity.
The labels look correct, but as always, 'let the buyer beware'. Never heard of that seller, so I obviously can't endorse it.
On Amazon, they have a listing for $119.99 per bulb from a reputable seller. That way, you have Amazon backing the return policy, authenticity, etc. Just a suggestion.
Old Feb 9, 2012 | 02:10 PM
  #48
JPMM's Avatar
JPMM
these
http://www.amazon.com/PHILIPS-Ultino...8825333&sr=1-1
Old Feb 9, 2012 | 02:18 PM
  #49
Theta's Avatar
Theta
Exactly. In the reviews, they're confirmed as genuine.
I'd rather pay more and be sure. Too many fakes floating around out there.
Old Feb 9, 2012 | 02:48 PM
  #50
JPMM's Avatar
JPMM
so do the lights look better?
its alot of dough
so does the difference make the lights pop? I always wanted the Mini to look a little more like the purplely Audis comin at ya
