Electrical -3,600 miles on service counter
hey guys,
got 2 minis of my own, no problems. my sister-n-law's 2005 R50 had cel on. The oil change count down is at negative -3600 miles (neglect). I change the oil, filter, reset the cel but I could not reset the count down counter to the next 15k setting. I tried using the tool different ways (like plug first then turn on and vice-versa but no luck. I'm wondering if since it's been negative for awhile that it will take longer to reset. never had this problem on mine since i don't let it go "0". Is there any trick to this situation? Anything i'm missing?
*would living the tool connected longer help?
*would disconnecting the battery?
*would resetting it from the dash/ignition/ODO button?
*do i have to donate an arm and a leg at the stealers?
any input is appreciated. (real or funny) Thanks!
You DO NOT use a tool to reset the counter in a gen1 MINI. (a very expensive shop tool can set a specific # for you in the countdown though)
The resetting of the miles is accomplished by entering the menu through the odometer re-set button.
Somebody will likely post a link with the directions, but a quick search will get you the instructions.
-3600 oil service indicator
gmonde
Sep 8, 2015 06:37 AM
JPMontes3
Aug 23, 2015 01:26 AM
Powershift
Aug 16, 2015 05:14 PM
