Electrical Driving light OEM switch, whats it look like when installed?
Old Oct 18, 2009 | 12:18 AM
WizardEyes's Avatar
WizardEyes
thinkin about getting OEM driving lights installed anyone had this done? where do they put the switch and what does it look like? is it pretty stock looking or very obvious that it was installed other than at the factory? i see the kit is about 350 from mini any one know what they charge for install as well?
Old Oct 18, 2009 | 07:46 AM
punkgeek's Avatar
punkgeek
It looks pretty stock - it is on the left side of the dash just in front of the steering wheel. It lights up green once pressed (defaults to off every time you start the car) and turns on when you press the high beams.
Old Oct 18, 2009 | 09:36 AM
WizardEyes's Avatar
WizardEyes
any chance on posting a pic?
Old Oct 18, 2009 | 10:13 AM
Oxybluecoop's Avatar
Oxybluecoop
Old Oct 19, 2009 | 02:40 AM
chris.j.lamb's Avatar
chris.j.lamb
Can also be fitted in the handbrake console opposite the tyre pressure monitor switch if you have a facelifted car.
Old Oct 28, 2009 | 11:50 PM
Eric_Rowland's Avatar
Eric_Rowland
And fits (almost) perfectly in the euro shelf (in place of the OEM knee bolster) as well.
Old Oct 29, 2009 | 02:07 AM
The-Only-One's Avatar
The-Only-One
There are two versions of the OEM driving lamp setup.
The 63 12 0 144 132 is the one with the mentioned switch.
http://www.realoem.com/bmw/showparts...=63&fg=95&hl=1
63 12 0 137 301 doesn't have one.
http://www.realoem.com/bmw/showparts...97&hg=63&fg=95
Make sure to order it right
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
