Electrical Output voltage lead tps wire...
Old Jul 31, 2009 | 06:08 PM
shadyj's Avatar
shadyj
Does anyone know where (I assume there is one?) the output voltage lead is from the throttle position sensor?
I am in the process of building a intercooler co2/water sprayer and want it to come on at wot when armed.
Thanks all!
Old Aug 5, 2009 | 06:30 PM
Step's Avatar
Step
I can try and remember to look for you tommorow if I get a chance. but either way, I think you might want to rethink your trigger meathod. If you tap into the signal going to the TPS. your most likely going to throw a fault and check engine light. the car will then drop itself into limp. the MINI thorttle valve is a twin potentiometer circut, that uses two exact signals to send it's values. any deviation from one another, or to a strict guideline and a fault is stored.
you may be better off using pezioeltric switch.
Old Aug 6, 2009 | 05:07 AM
BlimeyCabrio's Avatar
BlimeyCabrio
FWIW, it's pin 10 on the ECU connector and pin 1 on the throttle connector - I don't know which wire color that is, though.
Old Aug 6, 2009 | 01:59 PM
shadyj's Avatar
shadyj
I used the 10 pin on the ECU. I just t-taped into it-all I needed to do was read it-not use it as a trigger. It reads a tad under 10 volts at WOT. No codes, no limp. Co2 sprayer works like magic! Thanks for the info!
Old Aug 6, 2009 | 02:15 PM
BlimeyCabrio
Hmmmm.... odd.... should read about 4.2v at WOT....
pglgp1292
GP Talk (2006)
Oct 2, 2015 10:34 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
