Electrical Spark plug removal
Old Apr 10, 2009 | 05:07 PM
minimadness's Avatar
minimadness
Spark plug removal
Well I just purchased new plugs (Brisk) and was wondering what length and diameter ratchet size I would need. Help
Old Apr 11, 2009 | 02:33 PM
minimadness
4 get it I got it
Old Apr 11, 2009 | 03:12 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Just to be clear you want to install these when the engine is COLD. Before it is started in the morning is best. And DO NOT install them unless you have a torque wrench that can be set to 20 ft/lbs.
If you don’t know what I mean about the torque wrench you should seriously reconsider installing these yourself.
Rich
Old Apr 11, 2009 | 05:36 PM
miniconcarne's Avatar
miniconcarne
I use a 5/8 spark plug socket and at least an 8" extension. When I say spark plug socket I mean one with the rubber gromet inside to grip the plug on the way in and out. It's a long way down. Plus one on the torque wrench, these cars sometimes spit out plugs not torqued down correctly.(I think).
I also recomend anti-seaze on the threads and dialectric grease on the inside of the boot.
By the way, are these the 4 prong Brisks or single? If single, be sure to check the gap.
Old May 15, 2009 | 01:24 PM
ea6b607's Avatar
ea6b607
hehe, "mind the gap".... My 5/8" socket wouldn't grasp the plugs so I used a small piece of clay attached to a dowel to get my old ones out. Also, it is pretty dang deep, I had to use a 6" extension so that I could fit the torque wrench without removing the intercooler.
Old May 15, 2009 | 01:29 PM
silversmoke06's Avatar
silversmoke06
Just twist and pull gently.
You can do it.
09R56
Nov 16, 2022 10:49 AM
maniacalmorgan
Jan 1, 2020 11:20 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
yashmack
Aug 15, 2015 10:16 AM
