Electrical Trailer wiring help needed!!!
Old Mar 29, 2009 | 10:02 AM
subdude's Avatar
subdude
Folks, I need some help here. Went to install a Hopkins 46255 powered trailer light wiring harness, and things went downhill quick. Following this:
Power comes off the aux lighter socket + is the red wire with yellow stripes. Ground can go anywhere you can find a good spot to reach
On the left you can get the Left turn signal wire which is Blue with brown strip and the brake light which is Yellow with black stripe.
On the right side is Light purple with purple stripe. The tail light wire Mini-do-more says to take off of the solid blue wire. They say to take this wire from the loom before it gets to the right tail light socket
After many hours of trying to make this work, I did some investigative work and see that the tail light bulbs are not dual filiment, but single. It seems MINI is feeding low voltage thru the yellow / black wire for tail lights, and higher voltage thru the same wire for brake lights. Never seen it done that way before.
So, my Hopkins unit won't recognize the difference between tail and brake lights, it seems. Things get all flaky. Has anyone actually made this work, or do I need to toss the Hopkins unit and order the one from Mini Do More?
Old Mar 29, 2009 | 03:12 PM
paulsminis's Avatar
paulsminis
I originally posted this on the clubman thread and then later noticed you also asked here...
Subdude,
I got your PM and took a look at your post. However, I am not sure I understand the problem. However, according to what I read on-line about the Hopkins unit, it says it should work for most any configuration. I wonder if perhaps you didn't take the tail light connection from the solid blue wire on the right side that comes into the connector BEFORE the tail light connector. That is where Mini-do-more says to tap for tail lights. See if that helps.
Let us know....
Paul
Wohnson89
Jun 10, 2020 04:53 AM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
minipopkart
Aug 13, 2015 05:22 AM
BlimeyCabrio
General Mini related Ads
Aug 12, 2015 06:04 AM
