Electrical Water temp gauge sensor wiring question
Old Apr 1, 2008 | 03:10 PM
MiniJayhawk's Avatar
MiniJayhawk
I am using the Stewar Warner gauges (like the Autometer). I am putting the sensor in the water tank like the Alta setup. The instructions say that the sensor is grounded by its threads, but I am not screwing it into the engine block, but rather a plastic tank. I planned to add a ground wire at the same place as the sensor power wire on the bottom nut fitting and ground it in the engine bay. Is that going to work, or do I need to fasten a wire at the threads of the sensor and ground that?
Old Apr 1, 2008 | 08:38 PM
MiniJayhawk
Got it figured out. I wired the ground around the threaded portion. Works like a charm now.
Old Apr 2, 2008 | 05:50 AM
djam43's Avatar
djam43
Why would you want to know the temperature of the water in the make up/fill tank.?? Its a long way and a small hose away from the radiator and its cooled by the external air flow. Your reading would be greatly inaccurate.
Old Apr 2, 2008 | 06:30 AM
MiniJayhawk
It has been detailed in other threads, but that is not a simple burp tank. Coolant flows through there coming out of the block and is a good read of the temp.
Old Apr 27, 2008 | 10:44 PM
danielo's Avatar
danielo
Where did you tap the 'dimmer' wire to from the car?
Old Apr 28, 2008 | 06:35 AM
MiniJayhawk
In the same place that ALTA suggests, which is one of the wires running to the DSC button in the center console in front of the shifter.
Old Apr 28, 2008 | 06:47 AM
danielo's Avatar
danielo
Thanks!
Could you please tell me which wire that would be?
I do not have the Alta gauges and i am using Stri gauges
Old Apr 28, 2008 | 06:55 AM
MiniJayhawk
The gray with red stripe is the dimmed illumination to the DSC button. Use that.
Old Apr 28, 2008 | 09:10 PM
danielo's Avatar
danielo
Thank you.
Old May 13, 2008 | 11:26 PM
COR BLMY's Avatar
COR BLMY
Another interesting option is to ues the bleader screw as a location for the temp sender.
I run that and an OBD reader and it is interesting to watch the "flow" of temperature.
Old Sep 10, 2008 | 05:47 PM
paulsminis's Avatar
paulsminis
COR BLY,
What sensor did you use in the bleeder screw hole? And is it compatible with regular commercial gauges, like the SW?
Thanks,
Paul
Old Sep 11, 2008 | 04:21 PM
COR BLMY's Avatar
COR BLMY
Yup regular sensor with NPT thread ... just had to ground it.
I actuall bought another Bleeder coupler and cut the hose to install it
So now I have the gauge and the bleeder.
Old Sep 25, 2008 | 07:51 AM
donuttang's Avatar
donuttang
i got the m7 coupler, however, mine is R56 MCSa, the suggest hose already has 3 way(existing one)....than a 2 way which can be swapped easily.....so wherelse is better to be replaced....what about the coupler right underneath FAN behind the bumper??? would it be inaccurate?
Old Sep 25, 2008 | 09:35 AM
Big Daddy's Avatar
Big Daddy
Chad at Detroit Tuned had a coupler fabbed up for me that has both a bleeder valve and a bung on the bottom to thread the sensor into. Works like a charm.
Old Sep 26, 2008 | 02:25 AM
donuttang's Avatar
donuttang
i mean if taking the temp at that hose would be accurate or not, anyone know?
Old Sep 26, 2008 | 04:42 AM
Big Daddy's Avatar
Big Daddy
The suggested location is usually the upper rad hose.
Old Sep 26, 2008 | 07:07 AM
donuttang's Avatar
donuttang
i know, but R56s auto has a 3 way coupler, not the 2 way M7 that i just bought, therefore, want to know if the lower one is ok or not....
Old Oct 1, 2008 | 07:50 PM
COR BLMY's Avatar
COR BLMY
Reading the temp at the radiator ...gives you well radiator temperature .
The T stat could be shut and the engine have serious temp issues.
you gauge would tell you nothing,...
Mine is set up this way because I use a scangauge AND the gauge with the sender at the radiator
For a daily driver the info gathered at the radiator (remember you still have a dummy light) this sould be fine.
Really for more useable data a scangauge / "like item" or a sender in the block / "T"ed at the sender by the dummy sender is better
Old Oct 7, 2008 | 08:21 PM
donuttang's Avatar
donuttang
crazy, after a long struggle, i have decided to use the upper hose. in which i cut off the part closer to the engine, because the part where near the radiator is too short to fit a coupler in. also, as on my MCSa, the upper hose that M7 suggested has a 3 way not a 2 way on a manual.... i assumed the M7 would fit...however.....shittttttttttttt.....it is not fit on the upper hose, it is too big to fit in a 30mm(outer) hose...i have to purchase a 28mm coupler locally to fit in the upper hose......
guys, i think there is a little leak from the thermo hole, what kind of seal should i put in?
The alta gauge works great.......
M7, if you have read this, can i send it back and get refund for the coupler?
Old Oct 7, 2008 | 10:47 PM
COR BLMY's Avatar
COR BLMY
On a NPT (pipe thread) some sealer or teflon tape is OK ...sealer of any other type is a "band aid"
remember ...if you read temperature at the hose or radiaror ...it may NOT be an indication of what is happening in your engine !
Old Oct 17, 2008 | 04:56 PM
scottab36's Avatar
scottab36
Seriously, go to www.scangauge.com and you will get your water temp and a whole lot more..... It will give you the water temp right from the ECU. Mine runs at about 220F-224F.
Old Oct 20, 2008 | 06:23 PM
pilotart's Avatar
pilotart
ScanGauge is a super idea, simplest install ever:
Shown above listing MPH (unlike speedometer, it is accurate), Buss Voltage, Ignition Advance timing and Coolant Temperature.
Push any of the white buttons and cycle that display through twelve standard parameter displays, or about a dozen more "Custom" items.
Old Oct 21, 2008 | 02:37 AM
scottab36's Avatar
scottab36
I have mine installed in exactly the same spot!!! It does work great. You can even program it to display horse power.
Old Nov 16, 2008 | 09:55 AM
Jankjo's Avatar
Jankjo
This is a stupid thought probably, but I sure wish the scan gauge was round instead of rectangular to match the other gauges a bit better.
Old Nov 16, 2008 | 11:24 AM
strobeyprobey's Avatar
strobeyprobey
I agree that the scangauge is kind of ugly and difficult to mount. I went with the PLX DM-200 gauge and the Alta pod. (sorry I don't have a picture of my setup yet, search this forum for PLX and you find a couple of pictures). Looks completely stock! And running the wire up to the display was very easy around the steering column.
