Electrical Xenon High's and Low's
Old Mar 24, 2008 | 06:33 PM
ZJedi945's Avatar
ZJedi945
I was wondering about something today when I was driving home at night. I have OEM xenon's for my low beams and I was thinking if I can put them on my High's as well. I was thinking an aftermarket kit h7's but the thing that I was worried about was is the ballast would make the hood to heavy. Also has anyone done this yet and if you have can you post some pictures. Before you post things about getting a set of PIAA's or Xenonmatch bulbs, I have a set of PIAA Super Whites 4000k and you can still tell that they are halogen's
Thanks Zach
Old Mar 24, 2008 | 06:39 PM
hemiheaded18's Avatar
hemiheaded18
https://www.northamericanmotoring.co...light=bi-xenon
Someone's already thought about so you're not the first to ponder it. It seems it could be done, just as stated, what about another ballast?
Old Mar 24, 2008 | 06:41 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
You'd just end up losing visibility as the high beam reflectors are shaped to work with halogen bulbs rather than xenon bulbs.
Xenon bulbs work differently than halogen bulbs and require an alternate reflector (or a projector) to work properly. What ends up happening when you put xenon bulbs in halogen reflectors is that the light isn't dispersed correctly and you lose a lot of the visibility. Often times the halogen lights will actually be brighter than the xenon in the incorrect housing.
Old Mar 25, 2008 | 02:04 PM
Crashton's Avatar
Crashton
Another benefit rarely mentioned. You'll blind on coming traffic. Lots of Honda's around here doing that very thing. Pretty awful lights.
Old Mar 25, 2008 | 02:45 PM
JPMM's Avatar
JPMM
If you do not use the HID high beams with oncoming traffic
you won't blind anyone Also the headlight unit does not have a shield in front of the bulb that would keep the glare down. But if you use the high beams with no oncoming traffic its a moot point. I think the biggest difference between halogens bulbs and HID capsules is the focal point. If they assembled the capsules to have the same focal point as the halogens they are replacing the lights should work OK.
Old Mar 25, 2008 | 03:07 PM
Rally@StanceDesign
You won't blind anyone if you don't use your highbeams around other people.....but your highbeams will probably be less bright than the low beams since the bulbs are in the wrong housing
Old Mar 25, 2008 | 04:57 PM
Crashton's Avatar
Crashton
High beams.... DOH!!!
Dec 23, 2015 10:36 AM
Bennyboy
Aug 18, 2015 07:28 AM
Aug 12, 2015 01:24 PM
