Electrical Driving Lights
Old Sep 24, 2007 | 05:17 PM
  #26
MNEEME's Avatar
MNEEME
That's what I'm thinking too. I'll have to run to the store and see what I can find. If not I'll buy a set of bonnet ones and bend the top flat to mount down there. See what I can find at the store first.
Old Sep 24, 2007 | 06:01 PM
  #27
MNEEME's Avatar
MNEEME
Anyone know the size of the mounting bolt on the Hella 500's?
Thanks in advance
Old Sep 26, 2007 | 02:29 PM
  #28
DixonL2's Avatar
DixonL2
On the wiring end - ever get that sorted? If you're running a 15a fuse it seems you're running the powre for the lights straight through the switch, not througha relay - not a great way to go with all that amperage through the switch, inside the car.
Consider wiring a relay so the power runs from the fuse box through the relay to the light, and the switch only switches the relay...
Back to your bracketry discussion...
Old Sep 27, 2007 | 05:36 AM
  #29
Speedwing's Avatar
Speedwing
DixonL2 is right on with his comment. That supplied 1 amp fuse is for the relay connection. The relay is what needs to handle all the amps. If you are running 15 amps through your switch, it had better be rated for 25 amps to be safe. You should be using some pretty heavy wire as well that is also rated for at least 20 amps. You might find that your lights can actually be brighter if you wire them correctly with proper relays and wire guages.
Old Sep 27, 2007 | 09:06 AM
  #30
lsnover's Avatar
lsnover
Anyone try the fog lamps from Autopia on Ebay that go in the bumper?
Thanks,
lee
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
