Electrical LED's Front sidelight??
Old May 15, 2007 | 03:10 AM
Maaij's Avatar
Maaij
Anyone tried this?
I got a fault code. When using LED's
How can I fix it?
Maaij
Old May 15, 2007 | 09:34 AM
rkw's Avatar
rkw
I've seen a post about it either here or MINI2. Apparently the R56 tests for working standard bulbs in the sidelights (like what is common for turn signals). You can "fix" it with a load resistor to simulate the load of a standard bulb, although you will lose the heat and power advantage of LEDs.
Old May 15, 2007 | 10:27 AM
Maaij's Avatar
Maaij
Thanks for the info rkw
How can I find out which resistor to use?
Old May 15, 2007 | 11:53 AM
rkw's Avatar
rkw
The load equalizer kit that autolumination sells for 5 watt bulbs has a 100 ohm resistor. Generally you want the use the highest ohm value that will fool the computer, to minimize power usage and heat. If I were experimenting on my own, I would start at 500 ohms and go up or down to zero in on the optimal value.
gknorr
Aug 24, 2015 06:39 PM
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
FLYM1N1
Aug 15, 2015 11:20 AM
