Mini Cooper Intake Kit from K&N
Old Feb 19, 2016 | 02:52 PM
Mini Mania's Avatar
K&N Typhoon™ Intake System for your MINI! Dyno tests showed 8.51 hp gains! Built for performance and show, the Typhoon™ Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit the MINI Cooper S models with the N18 engine.
The restrictive factory air filter and air intake housing are replaced by the K&N Typhoon™ air intake which is designed to dramatically reduce air flow restriction as it smoothes and straightens air flow. This allows your engine to inhale a larger amount of air than the factory air intake. More air means more usable power and acceleration throughout the engine’s RPM range. This Typhoon™ kit comes with a black rubber topped K&N high-flow air filter and a rectangular heat shield that installs into the previous air box space. Air is directed through the intake tube into the engine’s throttle body for a guaranteed power gain. The intake tube has an attractive silver powder-coat finish that's made to last and it accommodates the factory mass air sensor. The oversized tapered cone-shaped air filter can be used for up to 100,000 miles before servicing is needed depending on driving conditions. This air intake is relatively easy to install usually in 90 minutes or less using existing factory mounting points. The tools needed are a screwdriver, ratchet set and several wrenches.
cdavidell
Jan 20, 2016 01:50 PM
Jan 19, 2016 11:38 AM
Jan 18, 2016 10:38 AM
Jan 15, 2016 03:30 PM
Suspension Products
Jan 13, 2016 12:31 PM
