GT Dominator™ Turbocharger Upgrade MINI Cooper
Old Feb 18, 2016 | 11:45 AM
Mini Mania's Avatar
The MINI Cooper Turbo JMTC Billet GT Dominator™ is designed to outperform the GT28 Turbo upgrade in performance, value, and ease of installation. This is a true 'bolt-on' upgrade!
Description
JMTC Billet GT Dominator™ is a high flow K04 direct bolt in upgraded turbocharger that is engineered to dominate the biggest GT turbochargers and fits all 2007+ Mini Cooper S. This is the number one best upgrade for if you want to dominate all GT28 turbocharged Mini Coopers. Great for applications that need over 300hp.
GT Dominator™
  • Huge high flow Billet 47mm compressor
  • Huge high torque exhaust turbine
  • Upgraded 360deg bearing
  • High strength K04 internals
  • Designed for higher pressure
  • High temperature alloy turbine housing
  • Dual scrolling turbine housing
  • Water cooled bearing housing
The JMTC's Billet GT Dominator TM is our answer to dominate the GT28 and it does that in much more ways than just performance. This extreme high-flow dual scrolling turbo dominates by giving you better response, quicker spool time, more power, higher torque, and because it is a dual scroll it gives you extended power and torque above and beyond the capability of the GT28. And the Dominator™ delivers it without the excessive tuning, tweaking, and expensive maintenance required by the GT28. So if you are looking for the entire power band (and not just all at the top-end) you can get out of a Mini Cooper than this is definitely the turbo for you. (Click on the following link for the complete article http://new.minimania.com/GT_Dominato...harger_Upgrade )
nshannon29
Jan 22, 2016 06:50 AM
cdavidell
Jan 21, 2016 01:49 AM
cdavidell
Jan 20, 2016 01:50 PM
cdavidell
Jan 20, 2016 01:46 PM
Jan 20, 2016 10:27 AM
