Mini Cooper Turbo Install Kit Oem R55 R56 R57 R58 R59 R60 R61
Old Dec 24, 2015 | 11:06 AM
Mini Mania's Avatar
Part No: G2NMK2222
SALE Price $79.95
Was: $95.60
You save: $15.65
Convenient Turbo Installation Kit with MINI factory replacement parts. If you are servicing the Turbocharger, get this kit for the critical items that you need to replace. This kit includes:
  • Oil Supply Line 1 ea
  • Gasket for the Exhaust Manifold 1ea
  • Gasket for Downpipe 1ea
  • Gaskets for Oil Supply Line 4 ea
  • Gaskets for Water Lines 4 ea
  • O-Ring for Oil Return Line 1 ea
Read below for an explanation on why you need to replace the oil supply line
Fits the following Cooper S models:
2007-2013 R56 MINI Cooper S Hardtop
2008-2014 R55 MINI Cooper S Clubman
2009-2015 R57 MINI Cooper S Convertible
2012-2015 R58 MINI Cooper S Coupe
2012-2015 R59 MINI Cooper S Roadster
2011-2016 R60 MINI Cooper S Countryman
2013-2016 R61 MINI Cooper S Paceman
NOTE:
  • Additional parts may be necessary, but these are the most 'critical' parts that should be replaced.
  • When servicing the Turbo on the MINI, it is very important (maybe even critical) that you replace the Turbo Oil Supply line to avoid potential future turbo issues.
Over time, the turbo and turbo supply line builds a fine layer of 'coked' or cooked oil on the internal surfaces. When you remove the supply line from the turbo, this disrupts the continuity of the coked layer with great potential of some of the coking to flake free. These coked oil particles can easily clog the fine journals that feed oil to the turbo bearings. Once the the oil flow is compromised, it is only a matter of time for cascading failures that can damage the turbo and catalytic converter! Don't take a chance - REPLACE the Oil Supply Line!!
For added protection, take a look at the Turbo Oil Line Thermal Wrap.
For other TURBOCHARGER related products, see our TURBOCHARGER products page.
Once you've replaced the turbo and the oil lines, we strongly recommend oil changes more frequently than the factory recommended interval. Anecdotal evidence suggests that cars with more frequent oil changes are seeing much fewer turbo failures compared to cars that followed the manufacture's recommended intervals. We recommend about 5000 miles or less between oil changes.
Take a look at these informative videos that will help you avoid potential pitfalls with the Turbo:
Aug 16, 2016 01:37 PM
AvianMan
Nov 3, 2015 11:00 AM
Nov 1, 2015 12:03 PM
Oct 29, 2015 11:04 AM
Suspension Products
Oct 29, 2015 10:23 AM
