Jcw Mini Cooper Air Filter Upgrade R52 R53 Value Line
Old Oct 13, 2015 | 02:40 PM
Mini Mania's Avatar
Part No: NME4515
SALE Price $89.95
Was: $129.00
You save: $39.05
Here is an economical replacement with a clamp for the JCW Cold Air Intake.
If you have the optional John Cooper Works air intake then you've got some work to do. When John Cooper Works created their Mini Cooper S airbox they neglected to use a high flow performance air filter. Unfortunately, their JCW Mini Cooper S air box still uses a paper filter element, which is very restrictive, significantly limiting airflow. This replacement high flow velocity stack filter is a direct fit and installs in 5 minutes.
This Mini Cooper S High Flow Air filter gives you both increased airflow and reusability at a very low price. Considering that their restrictive/ non-reusable John Cooper Works replacement paper filter costs $190 to replace, can you afford not to make the switch? The high flow Filter can be cleaned so that it may be used for a very long time if properly maintained.
Sep 4, 2015 01:32 PM
Sep 4, 2015 01:31 PM
Sep 4, 2015 12:56 PM
Sep 4, 2015 12:51 PM
Suspension Products
Sep 3, 2015 09:41 AM
