Mini Cooper Clutch flywheel Limited Slip Differential upgrades
Old Aug 21, 2015 | 11:11 AM
Mini Mania's Avatar
Heavy duty use requires Performance parts. If you are using up your tires or your clutch it may be time to step up to a higher performance clutch and flywheel assembly. The limited slip from OS Giken can actually not only make the car handle better but could actually save times by eliminating tire spin.
Large selection of Clutch Kits for both street and high performance can be found here- Click here!If you are looking for Factory Original Flywheel and Clutch parts- Click here!
Our Technical support staff is ready to help - call 800 946 2642
Confusion of multiple options can be reduced by insuring that you "Shop By Car" in the upper right corner of the screen to select your exact year, make and model of MINI.
http://new.minimania.com/ss/ENGINE-T...,DRIVETRAIN_NM
Old Sep 17, 2015 | 09:27 AM
ridinDirty's Avatar
ridinDirty
What is your fix for street performance for the R56 ?
Clutch master- junk
Valco- junk
Giken- great track, little bit of noise,not good in traffic ??
andrewjg1994
Jan 29, 2021 07:45 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
