Drivetrain Alta CAI install
Old Apr 23, 2007 | 07:29 AM
Chris Mo Rada's Avatar
Chris Mo Rada
Alta CAI install
i just installed the Alta CAI on my 05 MCS and i have to say im not impressed.
Before i start naming specifics i need to ask a question. I looked on the how-to's here and re-read the instructions and i cant confirm whether or not you are supposed to reconnect the stock air inlet tube from the fron the grille to the bottom portion of the stock airbox.
It only makes sense to me to seal of the bottom portion of the airbox so the heated engine air doesnt make it to the filter.
Could someone confirm this for me?
Thanx
Old Apr 23, 2007 | 07:38 AM
shankrabbit's Avatar
shankrabbit
Yes, connect the ram air pipe back to the bottom of the box. This pipe provides lots of yummy air when you are moving.
EDIT: (I should mention, I don't have an Alta, I have the Helix CAI and the ram air pipe is connected... but for common sense reasons I can't think why the Alta would be different.)
Old Apr 23, 2007 | 07:41 AM
minimusprime's Avatar
minimusprime
yes leave the stock inlet tube on as well as remove the back cowl sepparator. I'm not sure what you are looking for in a cai. An intake is really only an intake and it's not going to do much for you then maybe a touch better throttle responce and some sound. If it gives any real hp, it's for certain not much.
I think the cai does decently for what it costs. You can't spend $200 and expect the world when alot of people dump between 5-7k in their tritec's and only see 40-60hp over stock.
Old Apr 23, 2007 | 07:59 AM
Chris Mo Rada
ok, ill reconnect it and let u guys know..
yea i pretty much know what to expect from a CAI on a forced-induction car. I actually only put it on for a more aggressive sound But i guess because the box is not sealed, i dont get the aggressive sound. It pretty much sounds stock so im going to put the hose back on a see if there is any difference.
Old Apr 23, 2007 | 08:10 AM
shankrabbit
Maybe it's because I got the 15% pully put on at the same time, but there is no doubt you should hear it! It is NOT subtle either.
Did you remove the heat shield behind the filter to allow air from the driver side cowel to get in?
Old Apr 23, 2007 | 08:33 AM
Chris Mo Rada
i dont think so... if ur talking about the piece closest to the firewall then no. I cant see my firewall from this angle..
i though i needed that piece to mount the heat-shield to. Ill check again and take it out. I must be sufficating my car right now
Old Apr 23, 2007 | 09:37 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Chris:
Is the photo supposed to show how you are mounting the CAI? You should leave the bottom section of the stock airbox in place, (to which the front air duct connects), and simply install the metal "box" of the Alta CAI to the stock lower box section. I note you have removed the rear piece that allows air from the cowl to enter the CAI--this is good.
Old Apr 23, 2007 | 09:38 AM
shankrabbit
Originally Posted by DrPhilGandini
Chris:
I think that picture is from Webb's HowTo.
Old Apr 23, 2007 | 09:45 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Here is a pic of mine. You can see the heat shield removed from behind the filter and the bottom of the airbox still in place. Is this what your setup currently looks
like?
Old Apr 23, 2007 | 10:29 AM
Chris Mo Rada
yea that pic is from the how-to..
but no, i didnt remove the "cowell" in the rear. I'll do that when i reconnect the inlet hose.
thanx
Old Apr 23, 2007 | 11:04 AM
shankrabbit
thanx
Ahhh... remove that... THEN you'll hear it!
Old Apr 23, 2007 | 01:06 PM
IrishCooper's Avatar
IrishCooper
i dont understand how you could read the how to and not remove the rear cowl piece and not reconnect the air inlet, i used the same how to and did it on mine.
Old Apr 23, 2007 | 01:18 PM
BrewSwapGuy's Avatar
BrewSwapGuy
Formerly PassatDoTd
I didn't remove the heat shield when I put on my alta. That didn't matter sound wise as my car went from a sweet supercharger whine to a scream. Huge difference in noise.
Old Apr 23, 2007 | 01:24 PM
mikeg4572's Avatar
mikeg4572
I think you will notice an increase in performance when you remove it or cut a hole for fresh air.
Old Apr 23, 2007 | 02:26 PM
RedSkunk's Avatar
RedSkunk
A "RTFM" moment, agreed.
On the other hand, funny to hear someone say the alta sounds basically stock.
Old Apr 24, 2007 | 07:46 AM
Chris Mo Rada
it!
funny how that small little plastic piece muffles the blower. well i can def hear it now, sounds sweet. But not nearly as aggressive as some other people here were saying. I was expecting something obnoxious, but it sounds perfect.
thanks!
Old Apr 24, 2007 | 07:48 AM
Chris Mo Rada
i didnt.... i just used the instructions and when i looked at the how-to i was only paying attention to the inlet hose
Old Apr 24, 2007 | 07:54 AM
minimusprime
^^ I'm glad you enjoy it. for the record, not to be a jerk. But before you start posting threads with inflamatory to vendor titles, please make sure that the error is not your own fault. Exhaust all resources doing so.
enjoy the whine.
*e
Old Apr 24, 2007 | 08:16 AM
shankrabbit
enjoy the whine.
*e
+1
Old Apr 24, 2007 | 09:02 AM
DrPhilGandini
... But before you start posting threads with inflamatory to vendor titles, please make sure that the error is not your own fault. Exhaust all resources doing so.
Yes, the result is that we now have a thread with a most unfortunate title, that only moderators can edit. There really is nothing wrong with the Alta CAI, and Chris is quite happy with his Alta...but he's stuck with a thread he started that sounds like a whine.
Old Apr 24, 2007 | 09:22 AM
BrewSwapGuy
Formerly PassatDoTd
There's nothing inflammatory about the title. Its honest. It says "not impressed". It doesn't say things such as:
*Alta sucks
*Alta misled me
*Alta products are no good
*Don't buy Alta
If the title piques the curiousity of others they'll read the thread and understand.
Old Apr 24, 2007 | 09:26 AM
minimusprime
I have far far less faith in the general media consumer... especially the a typical american media consumer. Trite to blame it on that I know. But alot of people skim, speed read etc. Top that off with generally poor reading comprehension and I see it as an potential harmfull (allbeit miniscule) title.
I could be way off base. But if the ba in journalism has done one thing for me... it's to play your words to the lowest level of comprehension.
Old Apr 24, 2007 | 09:45 AM
Chris Mo Rada
??? guys... its the internet
besides, if people learn to read they can judge for themselves... for the record im still not all that impressed with it, especially for the money i spent. but thats just my $.02
thanx to u guys who helped me out...
Old Apr 24, 2007 | 10:44 AM
minimusprime
A few different issues in this post. This is the internet... but that excuse doesn't hold water. The internet has become the driving force in nitch markets such as car aftermarket stuff. Far beyond magazines etc ever could. Previously it was your local car club, but now it's a nationwide sharing of information that has made nitch cars explode with a vibrant aftermarket scene.
So what is, "Just the internet." to you. Is the sole support of other aftermarket companies.
As for your complaint about the product. Your complaint is more of a general complaint about cai's which could have been pre-empted through research about what they can and can't do for your vehicle.
I'm glad you got it working and such.
Old Apr 24, 2007 | 10:47 AM
shankrabbit
heh... when you're around NAM long enough you'll see that we're all one big dysfunctional family. There tends to be a lot of familial "bickering", but it's all in good fun and rarely are hard feelings ever harbored.
