Drivetrain Quetion about GIAC/MTH
Old Jan 9, 2007 | 12:19 PM
Bugs's Avatar
Bugs
I sent this to one of the vendors here, but thought i should post in the forums to get other opinions too.
My car is an 02 MCS 6 speed.
Current engine mods are
  • 15% pulley
  • Alta CAI
  • Milltek Catback exhaust
  • Denso IK22
I will likely be adding
  • Milltek Header
  • DFIC or Alta v2 TMIC
  • some sort of upgraded head/cam
I've been debating the GIAC vs MTH Tuner file for some time now. I am a big fan of the GIAC stuff on VW's, but know little about their MINI stuff.
I am sure the GIAC would be a great addition to my current setup, but im wonderring if i would more out of MTH if/when I add the header and head/cam?
Or will GIAC take those into account, and help them run better as well? Would i need different versions of GIAC software? or is it possible for cutom tune?
Old Jan 9, 2007 | 12:25 PM
S Curvz's Avatar
S Curvz
  • 15% pulley
  • Alta CAI
  • Denso IK22
  • Milltek Header
GIAC will be perfect for you until you ad the head or cam. GIAC does not do custom tunes up to this point. I have talked with a few tuners about using a piggy back controller to fine tune things when I add a head or cam.
I have driven cars with both and after doing so I went with GIAC. After talking to a few tuners and MTH, at that time, was not as constant of a tune. While it is "custom" it is hard to fine tune it when you have to send the file out.
Old Jan 11, 2007 | 06:30 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
I've had MTH for a long time before changing it for GIAC.
While the MTH Tuner software was very good, it still missed some fine tuning. My car was running smooth, but there was a little flatspot. It also increased torque under 3000RPM, but it still missed a little punch. Power delivery was not linear across the RPM range.
GIAC made my car runs much smoother and got rid of the flatspot. The engine pulls a bit more stronger across the whole RPM range.
I'm getting the 19%-injectors-GIAC update next week and I'll post my opinion.
Old Jan 11, 2007 | 06:42 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Does GIAC address the ASC/DSC traction control issues like MTH supposedly does? I haven't seen anything mentioning DSC in the GIAC stuff I've read...
Others have said that MTH makes the system less "nanny-ish"...
Old Jan 11, 2007 | 01:00 PM
Soul Coughing's Avatar
Soul Coughing
I love the GIAC on the mini, but it doesnt change any of the DSC/TSC systems....
Old Jan 11, 2007 | 05:53 PM
DarkMiniCooperS
It does not change the traction control... But hey, I always turn it off... except when roads are wet. Plus LSD helps a lot retarding traction control "intrusion" lol
Von Trapp
Dec 30, 2014 02:14 PM
davequick
16
Oct 25, 2002 11:28 AM
