Drivetrain Alta 3" Exhaust
Old Nov 16, 2006 | 07:00 PM
saifa's Avatar
saifa
Alta 3" Exhaust
Just wondering if anyone has any info / experience with this system. I am interested but remember reading somewhere a while ago that it did not fit properly.
Seann
Old Nov 16, 2006 | 07:38 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
I read on their site that this was intended only for the twurbo and other high pressure Minis.
Old Nov 16, 2006 | 08:10 PM
RebelToRumble's Avatar
RebelToRumble
3" for a I4?????
Christ, thats too big.
Old Nov 16, 2006 | 08:22 PM
sprp85's Avatar
sprp85
it should be great on tced cars
Old Nov 16, 2006 | 08:41 PM
xsmini's Avatar
xsmini
Originally Posted by RebelToRumble
3" for a I4?????
We've seen this big before, if I remember correctly it works pretty good. Superchargers change the rules
Nik
Old Nov 16, 2006 | 08:42 PM
TheBlackBrian's Avatar
TheBlackBrian
3" is great for performance. But in most cases it will be LOUD. That is probably why they are recommending TC cars to use it. But, if your hearing has gone bad already from fast cars, fast women, and rock music, you won't mind the extra dbs .
-Brian
Old Nov 16, 2006 | 09:08 PM
valcom111t's Avatar
valcom111t
I would think they are recommending it for TC cars because the TC creates some backpressure in the exhaust system since it is powered by the exhaust. That and the extra air being forced out. Superchargers don't create backpressure, obviously. I don't know the specific engineering, but I know that without enough backpressure engines can actually make less power than with some backpressure.
Old Nov 16, 2006 | 09:44 PM
spillman's Avatar
spillman
Today class we shall learn about turbochargers and how lack of back pressure quickens spool up.
Old Nov 16, 2006 | 10:59 PM
valcom111t's Avatar
valcom111t
That too.
Old Nov 17, 2006 | 04:54 AM
saifa's Avatar
saifa
Cool science lessons fellas.....but can anyone answer the questions I posted?
What is the quality and fitment of this exhaust? Anyone?
Seann
Old Nov 17, 2006 | 04:58 AM
dmh's Avatar
dmh
Originally Posted by valcom111t
... but I know that without enough backpressure engines can actually make less power than with some backpressure.
That statement is untrue.
Old Nov 17, 2006 | 08:05 AM
norm03s's Avatar
norm03s
"I know that without enough backpressure engines can actually make less power than with some backpressure."
Old Nov 17, 2006 | 08:42 AM
valcom111t's Avatar
valcom111t
I remember reading that somewhere, but I could remember wrong.
According to this link, that statement does hold some validity.
http://www.warnertechnology.com/Cars/backpressure.shtml
Old Nov 17, 2006 | 10:26 AM
dmh's Avatar
dmh
The link references 944s. Ask any PCA-CRer, if you want to be competitive on the track with one you best have a Stahl system!
Old Nov 17, 2006 | 12:21 PM
TheBlackBrian
That is refering to a N/A motor.
-Brian
Old Nov 17, 2006 | 12:59 PM
dmh's Avatar
dmh
-Brian
...and it's wrong.
Old Nov 17, 2006 | 01:14 PM
valcom111t's Avatar
valcom111t
-Brian
My original statement was meant as a broad statement, not specific to MINIs.
Old Nov 17, 2006 | 01:22 PM
valcom111t's Avatar
valcom111t
...and it's wrong.
Can you explain why? I'm just trying to figure things out.
Old Nov 17, 2006 | 01:30 PM
TheBlackBrian
...and it's wrong.
I was under the impression back pressure in the header was good for torque on N/A cars. Is this wrong? Can you point me to a place that will explain why? I am curious as well.
-Brian
Old Nov 17, 2006 | 01:34 PM
valcom111t's Avatar
valcom111t
Basically what I've found out from a short Google search is that you want to size the exhaust so that it doesn't lose too much heat as the air travels out, with the reasoning being that cold air is denser and harder to move than hot air. That being said, you don't want the exhaust to be too restrictive. There's a happy medium in there somewhere, supposedly.
Old Nov 17, 2006 | 01:36 PM
dmh's Avatar
dmh
You do not have to take my word for it. My suggestion is to read Internal Combustion Engine Fundamentals by John Heywood. Everything you thought you like to know or even try is most likely presented in The Book.
Old Nov 17, 2006 | 01:39 PM
valcom111t's Avatar
valcom111t
I don't think my library has a copy of it.
Old Nov 17, 2006 | 01:45 PM
S Curvz's Avatar
S Curvz
Wow, pricey book. Time to find a library
Old Nov 17, 2006 | 01:58 PM
kurvhugr's Avatar
kurvhugr
I keep linking folks to this thread on NAM and no one has told me it's full if &hit yet.....
Old Nov 17, 2006 | 02:02 PM
valcom111t's Avatar
valcom111t
"Some self-proclaimed engine gurus claim too large of an exhaust tube on a car can cause problems; engines need a certain amount of backpressure to run correctly. Although the statement about not running too large of a tube is correct, the assumption about engines needing backpressure is not. A vehicle needs the lowest backpressure possible to produce the maximum power by keeping pumping losses low. Too big of an exhaust pipe causes power loss, especially in low-end torque, because a big pipe has less exhaust stream velocity than a smaller pipe."
That's basically what I've been reading elsewhere.
