Drivetrain DFIC and boost
DFIC and boost
DRiving around tonight I achieved 18.5 lb of boost.....(ususally 16 is about it)the only thing different on my car is the DFIC..... it is 72 deg in Atlanta tonight..... I have some equip and will be making measurements this week.....no one is more surprised than me.....maybe something is wrong with the gauge but it seems fine the vac readings are normal.....hmmm
EDIT: Doh!! Thanks Matt
Backwords...
a LOWER pressure drop across the IC creates more boost....
I haven't tested the DFIC yet, but the pressure drops can be surprisingly large.
Note that this is no load data, with the car not moving, so actual airflow under full load will be higher... As will the pressure drops.
Matt
Matt
Thanks for sharing Bob!
I originally thought that boost was a little less with the DFIC, which would not be surprising given the nice temp deltas shared thus far. But, if such low temps can be achieved with increased boost, that would be spectacular!
Please share more of your testing Bob... thank you.
Matt, it sounds like you'll be getting something for testing quite soon... just not the DFIC, at least not yet. I'll let you know when I get mine, hopefully in the next couple of weeks.
I'll keep you posted....this is what keeps it fun
More boost is not necessarily a guarantee of more HP.
It's possible the restriction is prior to the combustion chamber and is restricting flow.
Higher psi but lower or maybe just less efficient cfm.
FWIW my intake manifold and snoots have been extrude honed......
I've looked at them and had an intake done years ago so I like the process.
It's a down the road project.
TIA
Did you like them when you got them?
TIA
TIA
But my layman thought is since boost is measured before the IC then if your boost goes up (after an IC change ) then the IC unit is more restrictive thus building pressure. Conversely, if it goes down the IC is less retrictive.
Having said that - when I switched from stock IC to the GTT IC, my max boost did not really change (just under 15lbs) but it seemed to take a little longer to reach the max boost. When I ran stock and nailed the throttle the needle would jump and go to 14.5lbs - now it seems to jump to 13.5 and then proceeds to 14.5lbs.
Originally Posted by Bahamabart
Matt clearly has a grasp on the subject so he is worth listening too!
Originally Posted by etalj
everyone i know gets boost readings from intake manifold, which is post IC. where else do ppl take readings from?
i thought it was pre - ic the location of the std vaccum tap?????
Are you talking about the std location of the vacuum source that the fuel pressure regulator sees? If so, this is definately on the intake manifold, which is post IC. This is the same vac source that the VGS system taps into
i don't think so.
LOL
LOL
LOL
LOLaren't you all glad I'm not a mechanic at your dealer !!!!!!!!!!!!!!
If you are measuring boost by the TMAP sensor, or with the usual tap-off of the fuel regulator source, you are getting the boost reading after the IC. In that case, it would seem that the DFIC is the least restrictive of what you had before it and your engine is seeing the most boost right where it should be, at the manifold. In that case, you got some good numbers.
Originally Posted by camelpilot
how does a gauge go off one day and not off on another? Loose? Bad fitting? Bad gauge? What gauge do you use?
Remeber that the DFIC comes with pre and post bungs, which will allow for
convenient pre/post boost or temp readings....
The bungs are
pre-threaded with an 1/8 NPT thread.
peter
team M7
562-608-8123
peter
team M7
562-608-8123
