Drivetrain So I'm shopping for an intake...
Originally Posted by RallyMINI
haha found it for ya https://www.northamericanmotoring.co...ht=jcampos+AGS
Originally Posted by MINIotaple
Is M7's CF heatshield not 360 degrees? I want the AGS so bad, it's just the installation that sounds like a pain considering I don't have several of the tools.
I wonder what the third iteration will be like...
I wonder what the third iteration will be like...V3.0 will be using CNC aluminum tube instead of rotocast plastic...snap fit. The sound should all be the same from V1 to 3. You trade some in cabin noise entertainment but share more of it with the outside world as the SC sound is much more pronouced and projected ahead of the Mini due to it's frontal location
Originally Posted by MSFITOY
M7's heat shield is covers the filter on top, drivers side and rear. I added a aluminum shield inbetween the motor and filter, effectively creating a U shaped enclosure to help guide the air into the intake.
Any chance V3.0 will incorporate something like that?
snip....... I believe this is( sic the M7 AGS) the truest CAI available to date (small force induction added with a modified 360 degree heat shield)
What advantage does it have over let's say.... the DINAN kit?
Just curious.
Originally Posted by obehave
Why do you think that's true?
Just curious.
Just curious.
As to why I think it sucks cold air...I have bugs in the filter
Does any other CAI have that problem?
Dianan is another airbox kit (albeit an exclusive kit) that sucks air through the cowl. AGS takes in air through through the front grill where the pressure is highest. It also has the shortest and least restrictive path of air flow compared to other traditional systems...
If you consider the supercharger to basically be an air pump, would blowing air at it actually speed up the flow of air downstream at all? Or would the speed of the pump completely control the downstream airspeed, effectively slowing down fast moving air and creating a high pressure area on the intake side and leaving the output unchanged?
Interesting questions, to me at least.
So it's not necessarily Cold Air Induction you're talking about but more just improved (possibly) air flow.
Now what we need to determine is which delivers the highest density air. Cooler or less restricted.
I think macncheese said years ago there are no real CAI's available for the MINI. I wonder if that's still true.
Originally Posted by XrayDeltaOne
I wonder if the force of air pressure is high enough, even at speed to add anything in terms of a ram air effect..? Making sure the path of the air flow is as unrestricted as possible and the amount of air available (under hood vs cowl area vs open to air) both seem more important factors.
So I'd assume( we know where that goes) that throwing a lot of air at the input won't matter once it reaches it's flow capacity at whatever rpm it's running.
Now if the air available is more dense you get something.
He can have his opinions but I do believe the AGS is the only true CAI...IMO
I've never seen any in depth pics of the AGS but I've thought that it still allows warm underhood air to enter the system.
I'd think the stock unit fits the CAI description better than the AGS does.
Let's ignore the flow restrictions since we know that's a limitation.
A roots/eaton design SC develops boost due to restrictiion post exit. It doesn't compress air internally like a centrifugal.
Ask and you shall recieve....
These are the pre SC pressures for a bunch of runs from my IC testing. This is using the HAI. With it and a 60 mm gen 1 M7 throttle body, you can see about an 8%-9% decrease in pre-SC air pressure as you go from about 2000 RPM to red-line. This is a bit less than 1.5 PSI. If you can get rid of this decrease by improving the flow path, you'll get more air out of the SC. It flows (pretty much) a fixed volume of air at SC intake pressure per revolution. Increase that pressure, and you will pump more molecules of air.
I don't have the numbers for stock.... But I did buy a new stock air filter, and a new HAI filter to see what the difference really is. Sometime I'll get around to it. I don't have any other brand of intake to test, but this is the best way to test the intake efficacy.
And the AGS is the only intake system that does anything post TB, so if that is a significant restriction, the other intakes just have to live with it!
Matt
Jeeeeesus. You are all way too serious. The energy just burned by this thread could have powered the car to Titan and back!!
Is there really that much difference among the three CIA's listed? For the difference among them, this enthusiast should go for whatever is easiest to install or whichever sound he likes the best. He's not racing the Porches at LeMans in the 60's for top manufacturer's honors, for Cnrist's sake.
Pick what you think looks best, sounds best, and makes your butt dyno sing!! May the farts be with you!
Matt
Matt
It definitely makes the AGS a lot more attractive if you're going after every last bit of power.
Looking at the pics of the AGS, I can really see why it would make a difference at high rpms where you're seeing the pressure drop. It really is a straight shot through to the SC with no twists or restrictions compared to stock.
These two images illustrate things really well:
AGS
Stock
Certainly makes the AGS look a lot more attractive to me knowing this.
Oh, and markldriskill, it's fun and we're learning. 95% of the time one intake won't be significantly different to another. Most of the differences will only be visible at high rpms once you get past the stock air box. But it's still interesting to see what improvements can be made.
I wouldn't call the AGS a better CAI then any of the others. If anything, i'd call it a HAI....
But who cares whether it's hot or cold air....all that matters is how dense it is....
The crimped plastic of the throttle body to SC inlet plenum would cause pretty bad airflow, and the AGS fixes this....what i think might be a good idea is the M7 AGS with a couple of ram pipes to make the air charge a bit cooler, and possible increase the ram-air effect...
At one stage of my MCS's life, i will be de-crimping the throttle body to SC inlet plenum, cos this would be a pretty bad restriction i think, that isn't necessary
Originally Posted by fishbulb
It has been stated many times, there is no ECU flash for the JCW intake. You need to splice a wire in. (my source is motoring file).
I use the ALTA and I am happy with it. I looked at others, I like that Alta replaces the Tube between the intake & the throttle body. Other intakes may offer fractions of a HP more, I am plenty happy with this one. I am too old to be trying to eek out every HP of a daily driver. A few nice mods for a little more HP & sound - i'm happy.
The Alta makes a bit of noise, nothing too offensive to me. I felt the stock MCS was a little too quiet anyway, so that was nice.
Anybody have an idea on how long the K&N airfilter for the HAI is supposed to last?
(edit) Nevermind, I guess it's supposed to be reusable.
Cheapest and best for the least amount of money...
HAI all the way. As the variances between all the intakes are minimal at best, the choice comes down to what camp you sit in and what value you put on looks. you can't really go wrong with any of your choices, just how much money you want to keep in your pocket for future mods!
