Drivetrain welding OBX header to stock cat
Old Feb 8, 2006 | 08:38 AM
The MINITOR's Avatar
The MINITOR
I'm taking my MCS to the shop this morning for instal, anyone have any more detail or pics on the weld between the header and stock cat. They'll figure it out I am sure, but its always nice to have more info beforehand. Thanks.
Old Feb 8, 2006 | 09:15 AM
Outbackbob's Avatar
Outbackbob
I read in one post that if you slip the OBX bell adapter around the cat inlet and draw a line where it stops then that is the cut point and that is where it gets welded.
Don't know if that messes with the proper overall length or not. You don't want any push or pull stress on the center rubber pipe hangers.
If you got a good shop I'm sure they will know what to do.
Make sure they double nut or use copper nuts on the spring bolts. Since they aren't in the kit they might not put them on.
Old Feb 8, 2006 | 09:16 AM
The MINITOR
That makes since, thanks.
Old Feb 8, 2006 | 10:15 AM
The MINITOR
and its the header adapter (flange) that gets butt welded to the cut cat?
Old Feb 8, 2006 | 10:23 AM
Outbackbob's Avatar
Outbackbob
I think of a flange as the oval shaped piece with 2 bolt holes the part that gets welded is the bell shaped slip connector with flange around it and not welded.
Old Feb 8, 2006 | 10:28 AM
Bahamabart's Avatar
Bahamabart
Correct - this ensure diameter consistency. Also weld should be stainless.
Measurering is a VERY good idea. Point this out to the installer.
This is KEY - you either double nut or cooper nut now OR you might as well make a second appointment w/ the installer. Before you go to the installer pick up either two cooper nuts or 2 extra regular nuts.
follow these points laid out by OutBackBob and you will be very happy with your header.
On last thing - many of us have had some manifold bolt difficulty (i.e. stock screw(s) not wanting to go in due to alignment. In my case I had 1 bolt that would not go in and I resolved the issue by shaving a little of the screw head diameter off (1/16 of an inch) others have bought new screws with smaller heads.
Old Feb 8, 2006 | 10:54 AM
The MINITOR
Looks like everything is going well at the shop, thanks for the help.
Old Feb 8, 2006 | 02:25 PM
KevinBaker's Avatar
KevinBaker
I found the easiest way to install the header was simply to ditch the bolts, and stick studs in the head.
Old Feb 8, 2006 | 02:45 PM
The MINITOR
Done. Now that is more like it. Vrooom...
Old Feb 9, 2006 | 10:36 AM
Outbackbob's Avatar
Outbackbob
Are you liking the header?
How's it sound with the stock cat?
Old Feb 9, 2006 | 11:59 AM
The MINITOR
I do like it. Exhaust sounds better, it was a little weak sounding before. And I feel the cojones!
Old Feb 9, 2006 | 03:19 PM
Bahamabart's Avatar
Bahamabart
Since I only had problems with one screw - I didn't go that route but this is a viable option as well.
Old Feb 26, 2006 | 06:35 PM
garretwp's Avatar
garretwp
I want to get the obx header, but still not liking the fact that no cat is included. I do not want to have to take the stock header off and then have it compared to the obx header for an aftermarket cat to be welded and fitted to the exact size. Does anyone have any good suggestions to have the obx header welded to a cat for a good size before I go to take off the stock header for install?
Garrett
Old Feb 26, 2006 | 09:14 PM
Dr Obnxs's Avatar
Dr Obnxs
All of this stuff is covered in the OBX Header Dyno Results thread....
But FWIW, you can get an aftermarket cat, take it down to the shop, and have it welded in as well. Make sure that you have the cat placed so that the 02 sensor "fits", and you'll need a 2 bolt flange to weld onto the end of the aftermarket cat.
For lots and lots and lots of details, wade through the original OBX thread....
https://www.northamericanmotoring.co...r+dyno+results
There are tons of photos there as well. I took some printouts to the shop that did my work....
Matt
Aug 21, 2015 10:36 AM
Aug 12, 2015 01:24 PM
rckrzy1
Aug 11, 2015 06:06 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
Aug 10, 2015 01:59 PM
