Drivetrain Alta Intercooler Mod.....
Old Feb 14, 2003 | 04:56 PM
Nobull60's Avatar
Nobull60
Intercooler
Has anyone bought this yet??? And if so where is the H2O tank mount and how is it driven??
_________________
Old Feb 14, 2003 | 05:36 PM
ALTAPerformance's Avatar
ALTAPerformance
Hello,
I don't know how many of the purchasers are members so I thought I would try to answer the questions for you.
The water tank is actually the rear window washer tank. Included with the kit are t fittings, hose etc. to connect it to the tank. You can choose to either have the sprayer come on with the rear wiper/washer or simply disconnect the rear wiper motor and the spray comes only to the i/c. You can also get a seperate tank for the i/c sprayer if you wish. We have an auxillary silicone tank and pump that will be available in late summer. Installation time is about 30-45 minutes.
If I can answer any other questions please feel free to call or e-mail.
Thanks.
Adam
ALTA Mini Performance
adam@altaminiperformance.com
Old Feb 15, 2003 | 08:13 AM
Nobull60's Avatar
Nobull60
Yes this looks really nice. Do you have any numbers backing the claims on the temp. change in the intercooler? Or did you just use some sort of thermometer? I live in South Fla. and I need all the coolness to the intersooler I can get. Thanks
Old Feb 15, 2003 | 08:19 AM
dominicminicoopers's Avatar
dominicminicoopers
Looks like something I might wanna get here in Phoenix!!
Old Feb 15, 2003 | 08:22 AM
kapolani's Avatar
kapolani
Are there any adverse effects of spraying water on the intercooler? Any problems with corrosion or anything like that? I'm assuming is treated to protect if from the elements, thus the hood scoop.
Old Feb 17, 2003 | 12:10 PM
orbhot's Avatar
orbhot
The kit seems to be in the beta stage. It would be complete with it's own tank, tubing, and switch. Ideal would be a temp activated switch that automatically turns the pump on when the intercooler gets close to being heat-soaked. Probably the most important in my eyes though, the kit should have an override to keep the pump off if the tank is empty. With a windshield washer, I can obviously see when no water is coming out (and know the tank is empty), but not so with this kit, therefore I could burn the pump out by keeping it on with no water to push.
Make these additions, and I'll buy one. Until then, I'm not going to try to guess whether or not the intercooler is hot enough to need to be sprayed and I'm not going to take chances on burning out my factory sprayer pump.
Old Feb 17, 2003 | 01:52 PM
LifeIsGood's Avatar
LifeIsGood
I'd like to see a small scoop in place of the "vent" under the driver side wiper for those of us that have cut out the back of the air box. Anyone else had thoughts about trying to "scoop" air into the air intake this way?
Old Feb 17, 2003 | 01:58 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Yep, a piece is in development that replaces the factory vent incorporating a scoop.
Randy
Old Feb 17, 2003 | 05:37 PM
paulmon's Avatar
paulmon
>>Randy
Cool! Just keep us posted Randy this is pretty slick.
Paul
Old Feb 17, 2003 | 07:58 PM
Yucca Patrol's Avatar
Yucca Patrol
>>Randy
looking forward to hearing more about this piece. sounds great!
Old Feb 18, 2003 | 08:35 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
I'd be interested in a thicker intercooler, with a modified hood scoop for clearance. The stock IC doesn't have much mass, so it can't work as a very good heat sink. Here's the stock IC:
Something like the WRX (STi -vs- standard) as shown in this pic:
Old Feb 18, 2003 | 09:56 AM
perfpow's Avatar
perfpow
I'd like to get a one inch thicker core plus raise it one inch for flow underneath. There's just nowhere for the exit air to go. That would require a new a new carbon fiber bonnett!
Sol
P.S. Shaker hood scoop???
Old Feb 18, 2003 | 10:09 AM
andy@ross-tech.com
Now you're talkin'! The best setup would be the most aesthetically-unappealing one. The intercooler ABOVE the hood.
Old Feb 24, 2003 | 10:40 PM
MCSHP's Avatar
MCSHP
I just got my Alta water spray today and I can say I am NOT all that impressed. You will loose your rear wiper. The instructions want you to disconnect it electrically and use its tank. I also wish that the air deverter would have been ABS plastic or carbon fiber. Its made from steel and is very heavy. I just think they came out with this way too early. They need the complete solution with the tank and intelligent water spray. Not the rear wiper.
The blue replacment silicone hoses are nice looking but the smaller of the two is the wrong size and needs to be re-addressed. Its a bit small making it very hard to get on. I cut my hand 3 times before I finally streched it enough to get it on.
I do like the deverter design and the location/quality of the water spray nozel.
All in all I think they have a ways to go but they are on the right track.
Old Feb 24, 2003 | 10:42 PM
MCSHP's Avatar
MCSHP
Oh one more thing I forgot to mention or really ask.
What kind of fluid would you run in the tank for this? Water is out in the winter and I also heard you must use distilled water or it gets crusty white clogging your intercooler.
Old Feb 25, 2003 | 10:29 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I agree Andy and Sol. There is a new intercooler under development - stay tuned!
I know there are at least two different people working on this, with two different approaches.
It shouldn't be too long before the news about them starts to trickle out.
Randy
Old Feb 26, 2003 | 05:15 AM
paulmon's Avatar
paulmon
>>Randy
What a tease!
Paul
Old Feb 26, 2003 | 02:34 PM
Grinder's Avatar
Grinder
>>Randy
Well, if you spilled the beans now then it wouldn't be long at all. So how about it Randy. Enlighten us....pleeeeease?!
Old Feb 26, 2003 | 06:11 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I can't d#mn it! I would if I could, but just wanted you to know it's coming, not to worry.
It will be interesting to find out the balance of going to big versus getting colder intake air.
Randy
Old Feb 27, 2003 | 05:11 AM
paulmon's Avatar
paulmon
>>Randy
I'm more interested in how they're going to fit it under the hood. Can you at least give us a hint of this requires a new or modified hood?
Paul
Old Feb 27, 2003 | 07:15 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
It depends on the design. There is definitely at least one that does not require a new hood, and one that might.
Old Feb 27, 2003 | 02:10 PM
paulmon's Avatar
paulmon
No new hood? Hrm, I'm now very curious as to how they are managing that considering how tight the MINI engine bay is. I'm sure you're not going to answer this follow up question but I figure I'll try anyways... Are we talking bigger intercooler or just "better" in some way? Better meaning the potential for a smoother inlet and outlet port, or something of that nature but not bigger.
How many would consider the replacement of the intercooler a "bolt on" modification? it's not exactly rocket science if that's all you change.
Paul
Old Feb 27, 2003 | 02:13 PM
mightyMiniz's Avatar
mightyMiniz
If the WRX scoop were used, and placed in an aesthetically pleasing position on the hood... It would not be accurate for flow into the proper area.
Old Feb 27, 2003 | 02:38 PM
orbhot's Avatar
orbhot
MightyMiniz,
Andy was not talking about using a WRX scoop on the MCS, he was talking about using a LARGER scoop, like the standard WRX vs the STi WRX.
Old Feb 27, 2003 | 04:16 PM
obehave's Avatar
obehave
>>Randy
I find that interesting. People told me I was nutty when I suggested that here months ago.
They also said I was nuts when I suggested tapping into the plenum under the windshield.
Still haven't seen a sealed, isolated version of that yet.
Should have gotten off my lazy butt on packaged that up
