Drivetrain Buying used parts
Old Nov 15, 2005 | 09:45 AM
phaedrus's Avatar
phaedrus
Buying used parts
I have an opportunity to purchase a used Milltek header and/or a used Schrick cam. They had been in use since April 2005. Of course, new would be ideal, but the cost savings is making this attractive. Are used cams and exhausts generally a faux pas? If not, is there anything I should look out for in terms of wear?
Old Nov 15, 2005 | 10:35 AM
autoxguy305's Avatar
autoxguy305
I've purchased used schrick 276 cams for my 16v volkswagen amd then had 30k miles on them. As long as the engine was maintained they will be perfect. My cams had no visable wear on them. As far as headers go, as long as the cat is clean, and there are no stress cracs it'll be fine.
How many miles are on the parts?
Old Nov 15, 2005 | 04:23 PM
phaedrus's Avatar
phaedrus
I'm guessing less than 10K mi; possibly less than 5K mi for the cam. I saw the cam and it *looks* okay, just a couple some hairline scuff marks. The header and exhaust likely have more wear; I forgot to ask the guy if they've seen winter salt -- an issue when you live where I do.
Old Nov 15, 2005 | 09:36 PM
autoxguy305
The cam will be perfectly fine, just clean it well before installing it, and install it with assembly lube.
Old Nov 16, 2005 | 11:22 PM
minicoop78's Avatar
minicoop78
dont buy a used cam I dont think its a good idea. header wouldnt matter though
Old Nov 17, 2005 | 06:34 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
A cam should be fine to buy used since it shouldn't have any noticeable wear from the vehicle. Now, if it has been kicked around a shop for a while and dinged up by ball-peen hammers, then all bets are off.
FYI, my general rule of thumb for used aftermarket parts is to price them at 1/2 the price new.
blackie
Oct 2, 2015 07:41 PM
xraycat
Aug 15, 2015 06:43 AM
messyjesse96
Aug 12, 2015 05:51 AM
nomar116
Aug 10, 2015 11:24 PM
