Drivetrain How about FLYWheel?
Old Nov 14, 2005 | 11:52 PM
Minirowski's Avatar
Minirowski
How about FLYWheel?
Is it better than a crank pulley and safe? Or it has own downsides like the crank pulley?
Also, has anyone here with a flywheel ?
Old Nov 15, 2005 | 04:55 AM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
MANY threads. Try a search.
Old Nov 15, 2005 | 08:52 AM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Some of us even have both.. Flywheel and crank
Oh btw i should be having a Spec LW/FLywheel for sale soon. I need to get on the horn with spec.. due to the ring gear stripping and ordering a new one. but if some one would like to buy it before i order the ring i will sell it both before and after i get the new gear. I'll even throw in the spec Stage 3 clutch that was attached to it when i replaced them.
This is not an Offical FS item as of yet thats why there is no price and im not putting it in the market place.. i dont plan on getting the ring gear until jan- Feb some time.
Old Nov 15, 2005 | 09:48 PM
autoxguy305's Avatar
autoxguy305
Magumi, if you sell your flywheel clutch setp within the next two weeks let me know, i'm about to get that same setup. BTW, how do you like it? and why are you selling? Just because of the ring gear?
Old Nov 15, 2005 | 10:29 PM
Mugami's Avatar
Mugami
Yes when the flywheel went i needed to order a replacement flywheel. I ordered teh M7 segment LW/ Flywheel with a new Spec stage 3 clutch .. simply you cant replace one without the other. the Car its self is running fine. even did an autox on Nov 13. So the old one is currently just taking up space and personally i dont like selling broken parts.. Used is one thing but strip broken , etc is another.
The set up is great once your use to it. only thing is the whole pedal engage or disengage is the top 1/4 throw which gets most people since there not use to it. I have very little problem with it in traffic unlike what a lot of people have posted about the set up in the past
www.members.aol.com/vsmcvid1/run2.asf
this is a vid of one of my runs with the new stuff installed.
Old Nov 15, 2005 | 10:56 PM
autoxguy305
As long as the ring gear can be replaced i'll take it. How many miles are on the setup?
Old Nov 16, 2005 | 01:30 AM
Mugami's Avatar
Mugami
ring gear should bealbe to be replaced its held in by 3 bolt not welded.. 15k on the clutch. PM me an offer i havent given it any thought yet on how much its worth.. if you want to call spec to get an idea of how much the ring gear will cost .. pls do so
QuickCooper
Jan 26, 2018 01:21 PM
vulkandino
Oct 31, 2015 08:29 PM
Sep 28, 2015 09:13 AM
SneedSpeed
Sep 21, 2015 06:06 AM
Sep 3, 2015 02:06 PM
