Drivetrain SuperTuner Challenge MINI Exaggerated?
Old Oct 24, 2005 | 03:31 PM
  #26
Rally@StanceDesign's Avatar
Rally@StanceDesign
Originally Posted by andy@ross-tech.com
Right. I was replying to the statement you made in the Performance Mods :: Drivetrain forum. Which is where you posted it. Which is where I replied. Which is where you are right now.
And how that disproves the fact that i was talking about the entire community is beyond me i guess . It is possible to speak of the whole community in general within the confines of the drivetrain forum without it solely being about the drivetrain forum. Your logic is slipping a bit andy
Old Oct 24, 2005 | 03:33 PM
  #27
Rally@StanceDesign
Originally Posted by jonnieoh
Another reason I <<personally>> put suspension mods further down my list are this: I have to drive in deep snow for nearly half the year. The ground clearance that I have with the stock MCS suspension is low enough for me to become a snowplow as it is... let alone if I were to lower my MINI with new aftermarket springs.
Yes, the look and benefits of better springs would be amazing, I'm quite certain, but because my car is a daily driver, all year long, I'm stuck with the stock ride height. (UNLESS, someone can direct me to better springs that DON'T lower the overall ride height...)
Now, one thing I can do, which won't affect ride height, is a new rear swaybar. That might go higher up on my list of mods...
A very good call. If you still want better handling after the swaybar look into struts. They dont lower the car at all, but they changed how my car handles a large amount.
Old Oct 24, 2005 | 03:37 PM
  #28
XAlfa's Avatar
XAlfa
Yes, the look and benefits of better springs would be amazing, I'm quite certain, but because my car is a daily driver, all year long, I'm stuck with the stock ride height. (UNLESS, someone can direct me to better springs that DON'T lower the overall ride height....
The drop on both the Dinan and JCW linear rate springs is on the order of only 0.5".
Old Oct 27, 2005 | 06:37 PM
  #29
jonnieoh's Avatar
jonnieoh
I know, I know...
A half inch lowering sounds like practically nothing to 90% of NAM members, I'm sure. But driving in the winter up here in the lake-effect snow belts is a big concern for a MINI. Not for traction, mind you, (provided you're using snow tires), but for ground clearance. I feel every 4-inch or larger ice chunk that falls off the car in front of me hit my lower air dam. Most times, it is slushy enough to just disintegrate. But sometimes, on those 3-below-zero days, hitting one is like hitting a bowling ball.
I am amazed at how tough the front air dam is, as I've come close to forcibly removing it with these ice chunks.
So, no, lowering the car even a seemingly insignificant half inch is out of the question for me.
Oh well, some parts of the country suffer from earthquakes, wildfires, tornados and hurricanes. I get lots of snow, and that's allright by me. I'll just have to suffer with the stock ride height for now.
Old Oct 28, 2005 | 02:45 PM
  #30
weaverpsu's Avatar
weaverpsu
The numbers....
They said it was very hot and humid which has a great effect on our beloved 1.6 liter Mini's. That should be in consideration when u look at the numbers for all of the cars especially the MM Car.
ludedude
Aug 10, 2015 07:16 PM
Aug 10, 2015 01:59 PM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
bctf1
Aug 6, 2015 12:55 PM
