Drivetrain alta short shifter HELP
Old Sep 22, 2005 | 05:17 PM
Harvchild's Avatar
Harvchild
Has anyone installed a short shifter without using the bmw linkage tool?I`ve tried and can`t get the linkage to come off the bottom of the shifter,the onethat pulls straight down towards the ground.Is there a trick to releasing this linkage Appreciate any feedback,thanks.
Old Sep 22, 2005 | 07:43 PM
XTREEM's Avatar
XTREEM
Yes there is..... Very carefully use a claw hammer. Slide the claws either side of the ball and lever and twist at the same time, being very careful not to break anything.
I spent a good hour trying to get it off, then thought of the claw hammer and it worked in 10 seconds.
John.
Old Sep 22, 2005 | 10:20 PM
QB's Avatar
QB
Hi Harvchild,
An alternative to the claw hammer (good idea Xtreem) is to just use an open-ended spanner to lever it off (I think a 3/8" fits perfectly from memory).
I took some pics at the time because I struggled for a while with this problem too.
Good Luck with it Mate
Old Sep 22, 2005 | 10:27 PM
J0kER's Avatar
J0kER
this is a 05 box! does the same go for an earlier box(white box) how hard was it to remove heat shields under car
Originally Posted by QB
Hi Harvchild,
Old Sep 22, 2005 | 10:33 PM
XTREEM's Avatar
XTREEM
Mine is a 02 think they are much the same. the heatshield is easy.
Old Sep 23, 2005 | 06:21 AM
LeeL's Avatar
LeeL
The linkage is a pain. I had to use a wrench like above and actually pry using the jaw like the claw of a hammer. I had to use so much force I thought for sure I would break something.
Old Sep 23, 2005 | 06:45 AM
J0kER's Avatar
J0kER
O2' O3' & early O4's are the same but that black box shown above is a O5' not the same set up as earlier model's.....
i should of done this while i had the exhaust out but for some reason i thought i would ruin the shield on its way out, im a little hyper and heavy handed at times. but if u say its easy it sure 'looked' that way to me
bahman
Nov 15, 2019 05:45 AM
rtk90
Aug 29, 2019 09:08 AM
Alanberto
Sep 16, 2015 07:25 AM
Mb460
Sep 14, 2015 05:50 AM
Emnotek
Sep 11, 2015 04:16 PM
