Drivetrain Questions about boost level
Old Aug 13, 2005 | 05:54 PM
gobble's Avatar
gobble
I just installed the Alta 15% pulley and my max boost level went from 10 PSI to 14 PSI. Is this normal? I was told to expect 17 PSI with the 15% pulley. I'm measuring boost using the Mini boost gauge accessory kit which mounts by the tach. It was dealer installed.
Old Aug 13, 2005 | 06:25 PM
M7's Avatar
M7
After data logging the boost levels straight from the ECU we have always
seen 13.7-13.8 psi worth of boost. There's absolutly no way to get
anywhere near 17psi worth of boost with a 15% pulley.
Your gauge is right on......go out and enjoy your new found power
peter
Old Aug 13, 2005 | 06:30 PM
kapps's Avatar
kapps
Yeah that's right. 15 lbs max for a 15% reduction. 14 lbs seems about right. The more mods you add to free up the flow path, the less boost you'll get. These will lower boost (and heat) but increase power - both a good thing.
Old Aug 13, 2005 | 08:46 PM
inmimini's Avatar
inmimini
boost level
i have 14 -15 psi on the guage with same pulley as yourself.
Old Aug 28, 2005 | 08:42 PM
J0kER's Avatar
J0kER
hey peter, will ur 16% give me 15psi worth of boost w/out any other mods except exhaust (milltek is what im using, if that matters)
(V.A.) be sending ur grills tomorrow cant decide if im going to keep the lower 1 or not. did U ship my pulley w/grill?
peter
Old Aug 28, 2005 | 09:07 PM
M7's Avatar
M7
I will send out your stuff on Monday....
As for boost, expect 14-15 psi. Call me tomorrow
peter
Old Aug 28, 2005 | 09:32 PM
J0kER's Avatar
J0kER
kool beans Yo!
peter
Old Aug 29, 2005 | 06:17 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
peter
M7, since your datalogger does not show gauge pressure, what were the actual readings that you got? FWIW, I've seen considerably higher boost with a 15% pulley than 13.7-13.8 psi both with my Omori mechanical boost gauge and using BiM-COM (which has over 140 times better resolution, and 60 times better sample rate than the Davis Carchip generic scanner OBD-2 scanner that M7 uses).
silence2-38554
98
Sep 21, 2016 02:52 PM
Emnotek
Aug 13, 2015 05:47 PM
flredmini
Aug 12, 2015 06:35 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
