Drivetrain Goodyear Gatorback Supercharger Belt
Old Sep 10, 2013 | 09:12 AM
  #51
juggerknot89's Avatar
juggerknot89
Gatorback 17% belt drive quality
Originally Posted by norm03s
No problems to date with apparently very little stretch.
The 6 Rib 53.75" sounds right.
Here it is, I just went out and found it; 17/19% pulley Goodyear part# 4060537 / part# 6PK1365 ( = the description, 6 rib, 1365 millimeters ) .
Effective Length 53.75", outside Length 54.5".
For what it's worth, I will use the same belt when it's time to replace this one.
Hey norm03s,
I also have a 17% pulley. For those of you out there using the Goodyear belt(part#4060537) on a 17% pulley:
How are you driving your MINI and how often are you replacing your belt? How visible is the hole on the tensioner when you install it? At replacement?
If you have your old belts sitting around, would you mind taking pictures of your used Goodyear ( part#4060537 ) belts. If it’s not too much trouble could you also find the inside and outside diameters of your used Goodyear belt? I’m looking at replacing my NAPA belt with a Goodyear and I just want to get an idea of when I should be replacing this belt.
If anyone out there has this info let me know.
Thanks!
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
JBsC6
New York/New England
Sep 24, 2015 02:41 PM
JBsC6
Sep 15, 2015 09:58 AM
Emnotek
Sep 11, 2015 04:16 PM
