Drivetrain Oil Gauges Sandwich style adaptor?
Does anyone know if anyone makes a product for us to install oil pressure and oil temp gauges. below is a link for a Wrx style adaptor. It would make things ten times easier.
http://www.wrxtra.com/sandwich_800x600.jpg
Here are some pictures
http://www.mini-madness.com/index.as...ROD&ProdID=219
What we need is plate to go between the stock cooler (above link in blue) and the housing for the canister. The red adapter they show has locations for oil pressure and oil temp gauge taps.
Just imagine a 1" thick plate with taps that bolts between stock oil cooler and the canister housing.
This looks like a good place to tap into the cooling system with an inline tap for a water temp. gage too.
This drilling canister tops and oil drain plugs doesn't suit me.
Yes
If you look at the picture the stock oil cooler (blue) is cooled by cooling system water. Those two nipples on the blue cooler are for cooling system water, in and out. The nipples on the red adapter shown are for oil lines.
If you scroll down they provided more info.
Pro Mini
In the long search for a part to make the install process a little easier. I finally found it. A little expensive but a much cleaner install then drilling through the oil cap.
Pro-Mini
[size=2]"We sell an adapter for the MINI that allows you to reinstall your
OEM oil pressure sending unit and has three 1/8 pipe thread provisions
for auxiliary gauges. This item is $49.95. We do not have an image as
this is a part of our gauge console kit. "
[/size]
Pro-Mini
[/size]
silence2-38554
98
Sep 21, 2016 02:52 PM
finn
Aug 21, 2015 07:59 AM
