Drivetrain Alta Crank Pulley
Old Feb 28, 2005 | 03:12 AM
strider209's Avatar
strider209
Alta Crank Pulley
I'm in the process of getting a 15% pulley and just started reading about the crank pulley. I'm a little lost as to the pros vs. cons of having an aftermarket crank pulley installed. I've read a few threads but still don't quite understand the benefits. Thanks in advance for any info!
Old Feb 28, 2005 | 05:04 AM
SpiderX's Avatar
SpiderX
I have been warned by three "tuners" to stay away from this for the street. (drag racing OK) Has to do with vibration dampning and like issues. I'm sure this will stir some debate but I'm going to let others be the pioneers on this one.
The benefit is the weight savings. Rotating weight has exponential properties and if you can save weight, in this case lots, your that much better off. However, if the engine requires the dampning properties of the stock pulley to keep from shaking itself apart.............
I am not a "tuner" and I don't play one on TV so this is only as I understand it. I'm sure other can give a much better explanation
Old Feb 28, 2005 | 07:43 AM
onasled's Avatar
onasled
Again, I'll give this link as a very informative read on this subject.
https://www.northamericanmotoring.co...ad.php?t=35290
I have the pulley myself and I rate it an A.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
VanisleRyan
Sep 13, 2015 09:55 PM
boydie
Sep 13, 2015 05:06 PM
Emnotek
Sep 11, 2015 04:16 PM
