Drivetrain Hissing whistling noise from engine bay.
Old Oct 22, 2019 | 07:31 PM
freestylin599's Avatar
freestylin599
Hey Nam,
I have an 11 MCS. 110k and has some bolt ons but still stock turbo. Recently I have noticed that I have some oil seepage around my valve cover, and the pcv tube as well. I had an incident about a month ago where I was idling the car for about 20 minutes and it started to smoke out of the tailpipe and shortly after about a week I noticed that the car at idle is making a somewhat loud hissing noise that sounds like it is coming from the passenger corner of the valve cover but I am not currently losing boost or have any CELs. Car still hold 18-19 lbs of boost steady to 5k. I was wondering if anyone knows about pcv failures because I know they are integrated into the valve cover and I am wondering if this would cause the car to smoke and make this noise at idle? Any input is appreciated.
Old Oct 22, 2019 | 08:00 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Mr grumpy posted a thread on how to cheaply change out the pcv diaphragm. It is probably torn and that causes the whistle.
Old Oct 22, 2019 | 08:18 PM
freestylin599
Thank you you I will do some research
Old Oct 22, 2019 | 09:27 PM
MrGrumpy's Avatar
MrGrumpy
yeah, it sounds like you have the torn diaphragm. they are super easy to fix.
Old Oct 23, 2019 | 06:41 AM
freestylin599
Thank my grumpy I found your thread and I've already ordered a new diaphram bravo on the write up
Old Nov 20, 2019 | 03:29 PM
2013coopy's Avatar
2013coopy
Pcv Diaphragm and spring?
Hello every one, I have the N18 engine I had the same problem and it was easy to install the new diaphragm but there was no spring in it, so I am asking if someone has a broken ir damaged cover all need is the spring for the pcv diaphragm, send me a message if you are interested and selling the part , thank you.
Xiaofeng
R60/R61 Stock Problems/Issues
Aug 2, 2019 04:53 PM
mikennet
R55 :: Clubman Talk (2008+)
Oct 23, 2014 11:52 AM
Nealuss
Jan 27, 2012 06:08 AM
bion
Nov 26, 2011 05:23 PM
hwang07mcs
Feb 17, 2011 04:02 PM
