Drivetrain will it fit?
Old Dec 5, 2004 | 01:28 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
will it fit?
Will this fit on my bmp? It says it can? Has anyone done it?
http://outmotoring.com/alta_silicone_intake_hose.html
thanks,
Jack
Old Dec 5, 2004 | 02:14 PM
littlehandegan
Someone please hook a brother up!
Old Dec 5, 2004 | 04:00 PM
onasled's Avatar
onasled
hmmmmmm, I afraid to say that I can't figure out what a "bmp" is
Old Dec 5, 2004 | 04:01 PM
littlehandegan
here ya go
http://outmotoring.com/bmp_s_intake.html
Old Dec 5, 2004 | 04:37 PM
Rick-Anderson's Avatar
Rick-Anderson
So what are you attempting to do - replace the filter and hose on the BMP with that of the Alta? I am considering doing the same thing but with a Dinan due to the superior filtering capacity of the foam Alta filter.
Old Dec 5, 2004 | 04:47 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
The issue is the size of the stock intake tube and the size of the Alta tube. The filter definitely won't fit - it's too big, as the BMP angles down.
The stock tube is 65mm at the neck - 60mm through the hose. The Alta is 68mm. What that means is that you have to take up the slack with a hose clamp - 3mm. It can be done.
I have all three colors in stock...
Hope that helps!
Randy
trw92a
Aug 26, 2015 01:47 PM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
