Drivetrain alta intake question?
Old Nov 17, 2004 | 10:40 PM
larkie's Avatar
larkie
is alta intake safe in rainy days?? i always feels that the filter will expose to water, since the back plate is removed.
Old Nov 17, 2004 | 11:01 PM
jinubob81's Avatar
jinubob81
i've had no problems.
i'd ask the people in florida. (all joking aside, hope you guys are getting along alright... now, where's my produce?!)
Old Nov 17, 2004 | 11:08 PM
larkie's Avatar
larkie
i thinking to put the back plate back on, and maybe do a little bit of mod on the heat shield. to make it fit. i don't know i should do that or not..
Old Nov 17, 2004 | 11:31 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
If you have the alta or know someone that does try this-
Place a piece of paper around the side of the alta filter that you feel is at risk of getting hit by water- not too snuggly. You want to test that it stays dry so put the paper in the intake area and close the bonnet. Then get in the MINI and drive it while your "friend- the myth buster" gets a hose and splashes the MINI like rain would hit the car. Do this a bit or until you get bored.
Now stop the car and let some of the water drip off. Open the bonnet and check the paper for any wetness from the water bath. If you find any moisture on the paper this is the extent of the rain's influence on the intake.
I'd expect not much impact. There is simply not a good path for the water to take to get to the intake under normal driving conditions unless the MINI is submerged.
End of MINI science experiment 25.
Old Nov 18, 2004 | 05:07 AM
onasled's Avatar
onasled
..... besides, a little water injection once in a while is good for the motor.
W0TM8
Dec 19, 2019 07:50 AM
AWOL
Mar 28, 2016 10:51 AM
Mib4840
Oct 13, 2015 10:10 AM
stierzy34
Sep 15, 2015 04:40 PM
jrezzo
Aug 9, 2015 10:32 PM
