Drivetrain Transmission swap
Old Oct 7, 2018 | 03:17 PM
R53anMe's Avatar
R53anMe
Transmission swap
Hi, all
I have a 2002 Mini R53 and want to upgrade to the post-facelift shorter ratio gearbox with an LSD. Will the post-facelift gearbox fit in a 2002 Mini Cooper s?
thanks for the advice
Old Oct 7, 2018 | 06:37 PM
Grey Lightning's Avatar
Grey Lightning
I’m fairly certain that it will. I think the boxes stayed the same, just the gear ratios changed.
Old Oct 8, 2018 | 06:31 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes it's a direct bolt in as they use the same case.
I would go ahead and upgrade to a Quaife LSD while you're doing it as it will be easy to do and so much better than the stock LSD
https://www.waymotorworks.com/quaife...ferential.html
zzMini
Jun 30, 2008 05:52 AM
nozaholic
Feb 1, 2005 11:17 PM
