Drivetrain Now chasing 2D52 (super knock)
Old Dec 11, 2017 | 07:13 PM
keithmcgreggor's Avatar
keithmcgreggor
Ok, after chasing the boost cut ( see the other thread ) and pouring over the logs, I determined that the car’s doing what it should. However, it did throw a plausibility error on the DV itself.
Today, removed the TurboSmart entirely to switch back to the uprated Pierbergh that came with the Frankenturbo... discovered that the banjo bolt at the DV of the vacuum line was free of the DV! Sorted properly now.
And now, I’ve got the infamous super knock codes. Swapped plugs for colder (1422s... planned to do this for insurance anyway) ... still got 2d52, misfires on #2. Swapped coils, still got 2d52 but now misfires on #3.
I’m thinking it’s not the plugs, it’s not coked up (fairly new block), it’s not broken lands, it’s not a single clogged injector. It’s not making the death rattle (timing chain is new).
Maybe it’s the AFR?
Maybe I should run it with race fuel to see if the code goes away? (But won’t that increase the chance of auto ignition?)
Maybe I should run it with a little E85? (But won’t that make the AFR out of sorts?)
Maybe the super knock sensor isn’t compatible with the 9.5:1 pistons?
Maybe it’s a dirty sensor?
Maybe the MAP sensor can’t handle the boost?
Maybe it’s the tune (since it’s substantially colder now than then)?
Maybe it’s the low pressure fuel pump not getting enough fuel to the HPFP (which I just replaced)?
Any ideas?
Old Jan 2, 2018 | 11:56 AM
blue al's Avatar
blue al
Hi Keith
Please empty your pm box...
I might have some insight into this
Old Jan 2, 2018 | 12:10 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Originally Posted by blue al
Hi Keith
Post your thoughts in the thread, then if anyone else has a similar issue it is easier to find solutions.
Old Jan 2, 2018 | 02:25 PM
blue al's Avatar
blue al
It's guesswork at this stage, will have some better info later this month
So would rather keep my powder dry for now
Old Jan 17, 2018 | 10:34 AM
Maikelveld's Avatar
Maikelveld
hi
I just bought a 2009 cooper s r56, with a 2d52 super knock code. any ideas how to track down this problem. no other issues.
Old Jan 18, 2018 | 03:52 PM
blue al's Avatar
blue al
I just changed the sensor
Tbf I could be just shooting the messenger, but no more codes
Check the torque before replacing.....
Old Jan 24, 2018 | 07:27 AM
Dr. Spade's Avatar
Dr. Spade
A little E85 is worth a try. Injectors should be capable of handling 30% just fine.
tominizer
Mar 7, 2011 04:31 AM
Darkness
Dec 9, 2008 11:51 AM
Jeffy
Cooper (non S)
14
May 14, 2008 06:46 PM
sprp85
Suspension
May 6, 2008 05:06 AM
bmarvin81
Jan 22, 2003 10:38 AM
