Drivetrain N18 Forge Recirculating Valve
Old Feb 19, 2016 | 01:18 PM
Mini Cooper r56 Pr's Avatar
Mini Cooper r56 Pr
Hi i just install a new Forge Recirculating valve FMDVR60R with the Blue Spring and i heard that i would not make sound or is to quiet but i have intake and when i dont go full throtle it makes a weird sound kinda like a subaru when they shift gears,i install everything like the instructions said,it have not got CEL or LIMP mode,does some one with the same setting ,FMDVR6OR and intake gave his feedback i would appreciate ,thankyou.
Old Feb 19, 2016 | 02:15 PM
hello, The forge uprated DV valve in that model is not a Blow off valve , so you will not get that big blow off noise, you will get a different noise with the open intake a bit ( not near as loud) . Do you have a clip ?
FMDVR60r
https://www.ecstuning.com/Search/SiteSearch/FMDVR60r/ES2723932/
Old Feb 19, 2016 | 02:44 PM
Mini Cooper r56 Pr
thank you i think i find the problem i am using the blue spring and the one that it needs is the yellow one.
Old Dec 15, 2017 | 05:27 AM
bongshi4's Avatar
bongshi4
Hi,
Can you help me with one issue on fmdvr60r?
I was following the instruction given from Forge to install this valve on my 2012 roadster S.
However, the instruction says to disconnect the wiring harness on stock DV, but it never mentions to reconnect the wiring harness to new solenoid module with harness adapter.
I assume that I must install this harness using the provided extension harness, but just wondering since it never mentions in the instruction.
Can you help me out?
Thanks.
Old Dec 15, 2017 | 05:41 AM
You use that little wire harness and attach it to the old line that you pulled off ( unplugged) on the factory DV ( diverter valve) then plug the one end to the harness and the other end to the little module with the vacuum lines all coming out of it three different ways. They just used blue lines vs black (ones that come with it) to show the orientation. Its on the second and last picture of the install PDF included for the MINI one.
Old Mar 11, 2019 | 09:40 AM
Just an update, we had a price drop on this part for a short time.
FMDVR60R
https://www.ecstuning.com/Search/SiteSearch/FMDVR60R/
Old Mar 15, 2019 | 07:09 PM
cyberlunacy's Avatar
cyberlunacy
you are hearing normal blow off through the intake tube. (sounds like a subaru shifting)
do you have an aftermarket cold air intake?
if so the blow off is normal through even the stock recirculating valve. i have the K&N intake and nothing else (until it warms up more) and you still hear the swoooshhh sound when shifting or accelerating.
thats the turbo sucking and blowing off.
wlambertr60
16
Dec 5, 2016 10:58 AM
PelicanParts.com
Feb 22, 2016 03:48 PM
PelicanParts.com
Feb 22, 2016 11:48 AM
budguy780
Feb 18, 2016 06:46 AM
takrdown
Feb 17, 2016 07:33 AM
