Drivetrain r53 rocker arm ratio??
Old Jan 5, 2016 | 07:00 PM
audio131's Avatar
audio131
Does anyone know the oem rocker arm ratio on a 2006 r53?
Old Jan 5, 2016 | 10:53 PM
Mini_Crazy's Avatar
Mini_Crazy
Intake: 1.65:1
Exhaust: 1.43:1
Old Jan 6, 2016 | 04:26 AM
audio131's Avatar
audio131
Awesome thanks..how about stock cam lift?
Old Jan 6, 2016 | 09:16 PM
Mini_Crazy's Avatar
Mini_Crazy
I believe this is correct for the stock R53:
  • lobe lift: Intake .202", Exhaust .217"
  • valve lift: Intake .333" Exhaust .310"
Also, the stock cam base circle diameter is 1.185" diameter. (On a regrind, this is ground smaller in order to create more lift. But you can quickly run-out of adjustment range in the hydraulic cam adjusters when you reduce the cam base circle.)
Old Jan 6, 2016 | 10:18 PM
audio131's Avatar
audio131
Cool. Thank you
ej
Jan 29, 2016 11:03 PM
minicooperlover22
Jan 15, 2016 06:32 AM
elisebr53
Jan 7, 2016 12:18 PM
Zillon
Jan 4, 2016 07:49 PM
suss1173
Dec 31, 2015 04:50 AM
