Drivetrain Forge FMDVR60A Problems
Old Aug 11, 2015 | 06:59 AM
Mini Cooper r56 Pr's Avatar
Mini Cooper r56 Pr
Hi I have a R56 n18 engine with Manictuning 2+ tune and bought the forge atmospheric bov,since I install it I have only seen problems first de valve adapter do not fit ,to be fitted you have to shave the plastic ,then when it was install it turn on the check engine light and the scan gave me this code P0030 = Diverter valve problems ,I uninstall the forge and install again the OEM and problem solve ,how has install this atmospheric BOV with success in the n18 engine ???!
Old Aug 11, 2015 | 07:46 AM
cerenkov's Avatar
cerenkov
It is understood that for the N18 engine an atmospheric BOV can commonly cause a CEL. Return it and get a refund if you can.
Old Aug 11, 2015 | 07:52 AM
Mini Cooper r56 Pr
Originally Posted by cerenkov
It is commonly understood that for the N18 engine an atmospheric BOV can cause a CEL. Return it and get a refund if you can.
Ok,Thanks
Old Aug 12, 2015 | 07:42 PM
Systemlord's Avatar
Systemlord
What you need is the Forge DV and not the BOV that vents to atmosphere, the problem with the BOV is the air being measured by the MAF is escaping and not going into the engine and the ECU sees this causing a CEL.
UncDeo
Nov 4, 2019 04:08 AM
rtk90
Aug 29, 2019 09:08 AM
tylewis
Sep 6, 2015 01:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
