Drivetrain M7 Throttle Body
Old Aug 11, 2004 | 09:49 AM
  #26
jlm's Avatar
jlm
we did back-to-back dyno runs way back in 2003, stock vs 61mm throttle body at Helix. no perceptible power or torque differences. My rig at the time was not a heavy breather (pre-head mod), although it had 15% pulley, header, exhaust, intake. We even did a full throttle run with the intake removed to peek in the TB to determine if the bfly was full open. It was and it was hairy.
Old Aug 11, 2004 | 10:01 AM
  #27
Normalizer's Avatar
Normalizer
Just installed a 59 TB, made by another company that I won't mention, and it made a really big difference. Assuming all TB's are the same, I can only imagine what a 63 would do....
'02 MCS with BMP air intake, John Cooper Works kit, and the new bigger throttle body.... my car is now fully capable of scaring the bejeezus out of me speedwise. An amazing additon the tb was, and one that I don't think enough people give credit to.
Old Aug 11, 2004 | 12:59 PM
  #28
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Dinan makes a 59.75mm throttlebody for the MCS that they do recommend to MINIs with JCW kit. Funny how the dyno tests done do not substantiate your perceived gains. I'd like to see more testing done to figure out under what setup will the rebored throttlebody and in what size will allow for gains that "ARE" measurable on dyno.
A larger bore throttlebody does not ensure any better performance. It's the total design fully tested that will tell the tale.
Old Aug 11, 2004 | 02:08 PM
  #29
andy@ross-tech.com's Avatar
andy@ross-tech.com
Actually, perceived performance can be quite different than measured performance in this case since a larger TB opens allows more air in at a given throttle angle. This results in a sensation of "better throttle response". A similar sensation could be enjoyed by sawing the gas pedal in half.
Old Aug 11, 2004 | 02:18 PM
  #30
Bisch's Avatar
Bisch
OMG, here comes "Operation Half Pedal".
Old Aug 11, 2004 | 03:03 PM
  #31
Normalizer's Avatar
Normalizer
The top half or the bottom half? I've got a hacksaw at the ready and am prepared to go....
Old Aug 11, 2004 | 03:14 PM
  #32
Bisch's Avatar
Bisch
no, no, no. Straight down the middle. That's how I just did mine...
Old Aug 11, 2004 | 04:59 PM
  #33
minispilot's Avatar
minispilot
Originally Posted by jlm
I'll spill the beans...
drill out the peened over ends of the torqx bolts holding the butterfly to the shaft (don't FU the shaft with any scratches);
cut off the aluminum compression band to get at the interior. ;drive out the drift preventing the shaft from slipping out;
cleverly figure out how to unload the return spring, remove the screws holding the butterfly to the shaft, slip out the bfly, slip out the throttle shaft and intermediate gear. (of course you noted the correct gear mesh configuration and return spring trickery. (don't FU the tiny wipers that read the position pot)
make a jig plate to bolt the body to, set your position by dialing in the existing bore to within .000", rough out the bore to .030 of final size, then finish bore to size. deburr the edges. Of course you used some protection so funk wouldn't get into the needle bearings or the electronic mechanisms;
measure the resulting bore to .001";
prepare bfly blanks from .100 thick aluminum with two holes matching the shaft bolt postions;
make a jig plate to hold new bfly blanks at 7degrees off horizontal, mill the OD to the size of the finished bore less .002. deburr and file tiny flats about .015 at the shaft diameter positions;
trial fit the bfly to the bore; remember it's an ellipse, so it has to be oriented or it will jam and scratch your nice finish;
install the flywheel, using your clever method to disable the springs and maintain the correct gear and postions stop arrangement;
fit the torqx screws gentlyto center the bfly and check for free movement; lockticht and tighten the torqx bolts;
re-insert the drift (not so easy);
figure out a way to band clamp on the electronics cover;
no sweat. eh?
63 mm is about the max you can get away with as far as wall thickness.
Cheese would add a step by airfoiling the edges of the bfly and streamlining the shaft...
So in other words it's worth the $300
Old Aug 12, 2004 | 11:24 AM
  #34
scobib's Avatar
scobib
Old Aug 13, 2004 | 10:49 AM
  #35
k-huevo's Avatar
k-huevo
I don’t doubt the validity of sensation when it comes to perceptions of enhanced performance. I just want to share some observations I’ve made of the supercharger intake duct (the throttle body mounts on one end) and some of the thoughts provoked by it in relation to changes made upstream. The duct varies both in shape and volume throughout its length. By nature of the duct’s convoluted shape and rough fitment of the supercharger end piece, laminar flow is disrupted; shear forces imposed and ellipse induced volume losses experienced. There is a section of the duct between the vent tubes boss and bypass valve insert that is almost 10% smaller than the stock throttle body opening. The venturi effect of this restriction would result in a pressure loss at that section. The transition from the duct to the supercharger has numerous form and fitment limitations that reduce the effective intake area to something close to the stock TB bore.
Because of the duct’s restrictions, I think changes made upstream would be negated. However, based on reports of other’s significant power deltas, I would think the duct despite its shortcomings is not a major bottleneck in the air needs for a 1.6-liter engine. As far as I can tell, pressure readings taken by others that show a decrease in pressure drop using this or that mod have been measured at a point closely behind the TB. If someone has taken before and after measurements further downstream, please chime in. The few dyno charts I’ve seen tend to support the relative ineffectiveness of TB or intake modifications. In regards to intakes, just going from a dirty to a clean filter makes a difference, so I tend to view dyno results of different intakes with a jaundiced eye.
Since this is a first posting on this forum I think a disclaimer is in order. This posting is not an attack on the M7 throttle body or any one’s satisfaction with it. The thread has evolved into a general discussion on throttle bodies so I felt an extra opinion might be OK. This is only a theory based on observations, sensations and didactical enquiry. Please put your pitchforks away before coming after me. :smile:
Keith
Old Aug 13, 2004 | 11:01 AM
  #36
jlm's Avatar
jlm
what's up with the text formatting being explicity displayed?
I agree about there being other restrictions offsetting most intake improvement gains (mainly the head, exhaust valves(, and it probably varies from car to car.
what is "ellipse induced volume loss"? a flow in-efficiency due to the tighter radius at the ellipse small ends?
Old Aug 13, 2004 | 11:35 AM
  #37
AMPR's Avatar
AMPR
Having started this thread I'd like to clarify my position by stating that the M7 throttle body seemed to or at least "felt" like it respond better. Unfortunately, I don't have any dyno numbers to back any performance gains, or losses.
Nonetheless, having spent the last few days doing dyno runs (as you can see from the following post towards the end of the second page of the thread https://www.northamericanmotoring.co...t=29218&page=2 ) I think we, as a MINI enthusiast community, need to start documenting each of the different modifications, much like Randy of M7 did with their thermostat and Andy of Ross-Tech does with his HAI mod, and putting up real numbers here or a web page linked to here.
AMPR
Old Aug 13, 2004 | 12:01 PM
  #38
k-huevo's Avatar
k-huevo
I'm sorry about the formatting display.
Once a perfect circle becomes distorted (ellipse) it loses volume (ellipsis of area) even though its perimeter measurement remains the same. I realize there is nothing regular about any of the oval like shapes in the duct. Perhaps those are incorrect terms to describe the effect shape has on volume. In those portions of the duct that have close to the same or even larger perimeter measurements as the TB, the internal area has been reduced by its bent shapes. The section that has a perimeter measurement smaller than the TB bore is easily identified as a constriction.
Keith
Old Aug 16, 2004 | 09:29 AM
  #39
andy@ross-tech.com
I think what k-huevo is describing is known as "hydraulic diameter". The idea is that and elipse may have the same perimeter as a circle, yet the flow through it becomes worse. Imagine putting a round hose into a vice and slowly tightening the jaws. As the jaws are tightened, the cross-sectional area of the pipe becomes less and less while the perimeter remains exactly the same. Eventually, the hose will be completely flat and there will be no flow through it. Hydraulic diameter is an expression used to represent the diameter of a round pipe that would have the same flow characteristics of the ellipse in question.
http://www.lmnoeng.com/PipeDuct.htm
Old Aug 16, 2004 | 04:07 PM
  #40
k-huevo's Avatar
k-huevo
Yes, very good analogy, thank you. I sectioned the duct into six pieces. I chose interior perimeter measurement (for the sake of simplicity) as a means of comparison between each section. The very odd shaped sections would require tracings on graph paper to get truly accurate comparative results.
Keith
Old Sep 29, 2004 | 05:46 PM
  #41
Xman's Avatar
Xman
Quick question:
If you install a T/B after other mods (MiniMania stage II + unichip), do you need to "remap" the chip for optimal performance?
Old Sep 30, 2004 | 05:47 PM
  #42
SpiderX's Avatar
SpiderX
I would love to know which size TB to get for a MCS with unichip, Dinan intake, 15%, Borla exhaust. Is there an ideal size? What if you p[lan on a header, cam and maybe a head? Does that make a difference?
Old Sep 30, 2004 | 10:04 PM
  #43
maxmini's Avatar
maxmini
We have tried 61,62,63 mm TB's and have settled on the 62 for most applications . We have installed them on what could be called a basic stage of modification cat back exhaust, some type of improved intake and 15 % pulley as well as our fully modded cars some of which have posted on here with big valve ported and polished heads,tuned header, port matched intakes , modded TB manifolds, 15% pulley, light flywheel , cam ,400 cc injectors, LSD, NOS etc. In both situations the car starts perfectly , idles at 800 rpm +/- 5 % , does not load up nor fowl spark plugs. As a matter of fact with the exception of a slightly lower exhaust note you really can't tell you have made a change from the stock 58 mm behavior wise . We will provide 63mm on special order but really haven't seen a need for that yet. Hope this provides some insight.
Randy
Team M7
www.m7tuning.com
Old Mar 7, 2005 | 09:28 AM
  #44
red rage's Avatar
red rage
So, No proof of ANY gains ? I will wait on the NEEDED DATA to be displayed
Old Mar 8, 2005 | 10:46 AM
  #45
uae mini's Avatar
uae mini
That means that I would be paying $600 plus shipping
bummer.. hope the prices fall soon. Or maybe not coz of the work involved.
Originally Posted by maxmini
The price on the throttle bodies are $ 399 plus a $ 200 core charge at this time.
We have 61 mm in stock for the Cooper and 61,62 and soon 63 in stock for the S.
Randy
team M7
www.M7tuning.com
Old Mar 8, 2005 | 08:58 PM
  #46
maxmini's Avatar
maxmini
The cost of the TB has been reduced to $ 350 . It is now shaped similar to a velocity stack and is 64 mm reducing to 62mm at the plate. This is the reason we describe it as a 64/62 TB. The core charge of $200 can be avoided of course by sending in your TB prior to us shipping you one. I know it is more down time for you but that is one way to keep your cash outlay lower. Feel free to ask anything else you may want to know.
Randy
M7 Tuning
bahman
Feb 14, 2016 10:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Emnotek
Sep 29, 2015 07:37 AM
