Drivetrain endlink rubbing axle
Old Jul 12, 2015 | 05:18 PM
bmx175's Avatar
bmx175
Hi: I have a R53 2003, with 17" ultraleggeras, koni yellows and HR lowering Springs and i am having issues with the endlink of the driver side rubbing the axle when cornering. Does anybody has experienced this? What is a possible solution? Adjustable endlink?
Old Jul 12, 2015 | 06:10 PM
Rustyman311's Avatar
Rustyman311
Did it start rubbing recently or just prior to you installing the suspension?
Old Jul 12, 2015 | 08:10 PM
bmx175's Avatar
bmx175
I really didn't notice anything other than a clicking sound in when cornering, until i went for alignment and the guy showed me the scuffing in the axle. So i don't know when it started. I know that the shocks and springs have 2000 miles.
Old Jul 13, 2015 | 08:18 AM
Rustyman311
The clicking sounds like a CV going bad....are any of the boots torn? Do you have any pictures?
Old Jul 13, 2015 | 10:05 AM
bmx175's Avatar
bmx175
No. The boots are fine and the grease is new. I will try to take a couple of pictures and upload them.
Old Jul 13, 2015 | 01:45 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If the clicking is rotational when you turn your wheels, it is possible the axle is bad. It is possible for axles to go bad even if the boots are still intact. I'd suggest getting the endlink issue resolved and seeing if that illuminates the sound you're hearing. Do you have upgraded sway bars? Possibly getting an upgraded sway bar to help stiffen up the chassis will help get rid of the body roll you're seeing when cornering, which essentially may help resolve your current issue. (Options here). See if that helps and if the clicking persists, but you are no longer seeing the endlink rub, then start looking at other possible options.
888.280.7799 | 6am - 5pm PST
Old Jul 13, 2015 | 03:29 PM
bmx175's Avatar
bmx175
The clicking is not rotational, is like the axle is getting out of the transmission and getting back in, the clips are new and installed correctly.
I have upgraded 22mm rear swaybar, strut brace, and polyurethane bushings for the front stock swaybar. I think it has to do with bodu roll but i have a little of understeer as is. If i change the frobt swaybar that is going to get worse so that is my concern.
OutMotoring
Mar 3, 2017 06:29 AM
gknorr
Dec 26, 2016 09:38 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
vulkandino
Oct 31, 2015 08:29 PM
gknorr
Oct 1, 2015 09:20 AM
