Drivetrain Supercharger Pulley Upgrade?
Old Apr 17, 2015 | 06:11 AM
Shen456's Avatar
Shen456
Been looking at this for a cheap increase in power.
http://new.minimania.com/part/NME504...de-Kit-R52-R53
Will this reduce engine life any, some of the claims in the description of this part like a 20hp boost to the wheels seems kind of ridiculous... Also what is the difficulty of this install for a beginner?
Old Apr 17, 2015 | 06:41 AM
fridayxiii's Avatar
fridayxiii
There are lots of threads on supercharger reduction pulleys, and it's probably the most common upgrade for an R53. Running a smaller pulley won't shorten the life of your engine, but it could impact the life of the SC itself as you're spinning it faster.
15% is considered a really safe size. Many (including myself) run a 17% reduction, which is fine too unless you track your car or spend lots of time at the redline. 19% spins the SC too fast, resulting in excessive heat production and reduced performance.
No matter which size pulley you get, make sure you get the proper belt (inc. in the package you linked too) and some colder spark plugs. Way Motor Works sells the whole kit on their website.
Most use a special tool to remove the pulley, which you can buy or maybe even rent. After watching my mechanic do the pulley on my car, I'd suggest you find a local independent MINI shop to do the work.
HTH, and Motor On!
Old Apr 17, 2015 | 01:45 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
fridayxiii is right the pulley is the best bang for the buck for a supercharged MINI. We have a great kit with all that you need.
http://www.waymotorworks.com/wmw-pulley-package.html
I wouldn't be concerned with engine or supercharger reliability. If either is going to fail they will fail with or without a pulley. And to say it shortens the life is also IMO a stretch as I've seen more failed superchargers in my shop with stock pulleys than I have aftermarket so it's more about the car itself.
With the MM 3 piece pulley it is a bit harder to install so that is why our pulley is just the standard 2pc design.
Old May 23, 2015 | 07:39 PM
RogueMini's Avatar
RogueMini
^^. What Way said. Maintenance is critical on MINIs, if you take care of it, it should last may miles, small pulley or not. (Except the crank pulley) lol
Yes, a pulley will get you 20ish hp, more if you get a tune. Its not like headers or a cai where the sellers claim a 10hp increase on your mom's monte carlo, and all it really does is makes more noise. You will be happy with the pulley; thats why we all do it.
Not too hard to install the pulley; lots of "how to" insturctions (pelicanprts.com, minicooperspeed.com). You do need the special puller to get the stock pulley off. The one Way sells works perfectly.
blackie
Jan 18, 2017 09:56 PM
MoganDavid
Mar 14, 2016 10:44 AM
Toolman
Jan 20, 2016 06:50 AM
alistaircookie
Oct 8, 2015 10:52 AM
JPMontes3
Aug 23, 2015 01:26 AM
