Drivetrain Underwhelmed with AEM intake
Question on the low-end torque comment, has anyone ever dyno'd with AEM intake and without the intake? Not including AEM themselves of course. I have seen these comments before, but I've yet to see a dyno shoing how much less and exactly when its less. If that makes sense.
Agreed. Air density will certainly play a small factor in gains or losses. Also, has anyone ever installed an temp sensor after the turbo but before the FMIC? I'd be interested to see how the temps vary with Ambient temp. Again what the temps read during Cold VS Warm weather. Just so we see how much, or how little, ambient temps play part in post turbo temps
I'm aware he had an issue. In fact he said he would still be running the AEM intake if it wasn't for it slipping off the larger turbo inlet.
Hey guys, I've never made any improvements or changed to my 2012 Cooper S, this will be the first thing I'm looking to do. My main goal is just to get some more turbo sounds coming out of the engine. While at the same time not messing around with my MPG, or ruining the motor. I've looked on the market at several different systems, and they all seem fairly similar. My main concern with something like the k&n typhoon system is that it will be sucking in warm hot engine heat while sitting in Boston traffic, and while just going down the road 55pmh+
And I'm worried that if I remove the hood scoop grill, that it will allow rainwater to get into the system and ruin the motor, not to mention hert my MPG, does anybody have any experience with a system like this, or removing their hood scoop grill without damaging anything? And does a system like this actually improve MPG.
Please any input will help
I removed my hood scoop grille at the same time that I installed my intake, which was a year ago. No issues with driving in the rain, or anything having to do with hot intake temps. The one thing I did notice is my car dropped from 14 psi to 9-11 psi when it got cold (I have a mechanical boost gauge). I don't know if that's typical of these cars or not, and I didn't try going back to the stock air box to see if it changed anything. The boost came back with the warm weather.
I would suspect that a CAI will actually cost you a few MPGs when it gets cold out, although I'm not sure.
Sep 22, 2015 02:05 PM
potterstein
Sep 11, 2015 11:45 PM
